Home > Faults & Fixes > Fault Code B1B57
seankenyon
United Kingdom 2005 Range Rover Sport TDV6 HSE Arctic Frost
Fault Code B1B57
Knowing I had this fault code for the front & rear parking assist: B1B57 Power circuit earth to ground...
I replaced the front & rear parking sensors and the wiring looms aswell due to corrossion, afterwards I ran the diagnostic on my hawkeye which still showed the same fault, plus the the park assist warning light still flashes and sounds a warning for 3 secs upon turning the ignition, also the hawkeye isn't able to clear the DTC faults
So im wondering is is there a reset I need to get done by a specialist or LR Dealer?
Really frustrated after the time & money spent to try and remedy the problem so any help would be massively appreciated
Post #464211 Wed Jun 10 2015 9:42am
seankenyon
Anyone Question
Post #464783 Tue Jun 16 2015 1:35pm
chrisblood
2006 Range Rover Sport 4.4 V8 HSE Java Black
Got similar problems,main dealer is probably the only option I'm afraid.
Post #467202 Sat Jul 11 2015 9:39am
seankenyon
Thanks, might try changing the pdc module before I visit a dealer
Post #467249 Sat Jul 11 2015 8:11pm
seankenyon
Good news, problem fixed, ordered a used PDC Module from America £45 Inc postage
Only difference was the part number, I got a YWC500550 and what I removed was a YWC500313
I don't know what the difference is but I read that it should be YWC500550
Anyway a cheap fix, but bear in mind I also replaced a corroded loom and sensors first
Post #468851 Tue Jul 28 2015 5:28pm
