Home > General > What's this leaking?
RossM
United Kingdom 2007 Range Rover Sport TDV6 HSE Cairns Blue
I've a wet patch under the car towards the rear, just inside the rear driver's side wheel. When I had a quick look earlier the tank fill pipe was wet where there is a rubber coupling but it seems to be coming from a large cylindrical item above it. When I put my finger in the fluid it doesn't smell like diesel, looks and smells a bit more like clean oil. Could it be hydraulic oil of some type? Where's it coming from? 2007 Range Rover Sport TDV6 HSE- Cairns Blue with 22" Stormers
Post #464419 Fri Jun 12 2015 10:10pm
The rear diff breather pipe terminates near the fuel filler (it's clipped to the fill pipe). Might be coming from that perhaps. The only other thing that comes to mind in that area might be the charcoal cannister in the petrol fuel tank but as you have a diesel I assume that's not relevant. 2012 SDV6 - it's missing a couple of cylinders
Post #464423 Fri Jun 12 2015 10:37pm
RossM
Thanks RRSTDV8, I'll have another look and see if it's the breather. Might try getting a picture too. 2007 Range Rover Sport TDV6 HSE- Cairns Blue with 22" Stormers
Post #464556 Sun Jun 14 2015 9:53pm
