![]() | Home > General > What's this leaking? |
RossM Member Since: 27 Aug 2012 Location: Poulton-Le-Fylde, Lancashire Posts: 80 ![]() ![]() ![]() |
I've a wet patch under the car towards the rear, just inside the rear driver's side wheel. When I had a quick look earlier the tank fill pipe was wet where there is a rubber coupling but it seems to be coming from a large cylindrical item above it. When I put my finger in the fluid it doesn't smell like diesel, looks and smells a bit more like clean oil. Could it be hydraulic oil of some type? Where's it coming from? 2007 Range Rover Sport TDV6 HSE- Cairns Blue with 22" Stormers |
Thanks RRSTDV8, I'll have another look and see if it's the breather. Might try getting a picture too. 2007 Range Rover Sport TDV6 HSE- Cairns Blue with 22" Stormers |
