Home > Technical > 2005 air compressor upgraded, won't descent |
AndyKay Member Since: 14 Jan 2012 Location: Leeds Posts: 226 |
I had my compressor upgraded to the newer version all installed correctly and had to go to the dealer for the new software update, but when I try to descend to 'Access mode', it errors and goes into 'Extended Mode' and won't go back down. Only after switching the engine off and on again (IT solution ) it goes to normal height
Fri Apr 17 2015 10:58am |
Look at the 4x4 display screen, is one of the dots above the wheels flashing?
Fri Apr 17 2015 11:24am |
Nope none of the dots above the wheel are flashing when I try to descend RRS HSE TDV6 Autobiography |
Thu Apr 23 2015 11:39am |
Dropped it off at the local LR specialist and apparently the release valve is faulty. Not releasing air. Is the valve fixable? Quick look on Disco3 mentions something about greasing the valve up?
Fri Jun 12 2015 11:21am |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4396 |
More often than not, this is a calibration issue, instead of a faulty compressor.
Fri Jun 12 2015 11:46am |
Well it was in to do the calibration and they did attempt it but apparently the valve won't release RRS HSE TDV6 Autobiography |
Fri Jun 12 2015 11:48am |
Is the compressor valve a separate part? I keep reading about this 'Transfer relief valve' - looks a lot cheaper than a full compressor cost RRS HSE TDV6 Autobiography |
Fri Jun 12 2015 11:57am |
Quick update: it's an error in the 'venting gallery' if that helps? Is that an issue known with these AMK ones? RRS HSE TDV6 Autobiography |
Fri Jun 12 2015 12:46pm |
That's the issue I had with mine, but the suspension wouldn't work at all until the air gallery was empty, then the compressor would kick in |
Fri Jun 12 2015 6:34pm |
