Home > Technical > 2005 air compressor upgraded, won't descent
AndyKay
England 2005 Range Rover Sport TDV6 HSE Java Black
I had my compressor upgraded to the newer version all installed correctly and had to go to the dealer for the new software update, but when I try to descend to 'Access mode', it errors and goes into 'Extended Mode' and won't go back down. Only after switching the engine off and on again (IT solution Laughing ) it goes to normal height
Is there any experts I can take it to, to get it sorted? It's annoying since I spent so much on getting the compressor fixed, it doesn't actually work!! Big Cry RRS HSE TDV6 Autobiography
Post #459475 Fri Apr 17 2015 11:58am
Bodsy
Site Sponsor
Look at the 4x4 display screen, is one of the dots above the wheels flashing?
Could just need calibrating or a new sensor. Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #459481 Fri Apr 17 2015 12:24pm
AndyKay
Nope none of the dots above the wheel are flashing when I try to descend RRS HSE TDV6 Autobiography
Post #460236 Thu Apr 23 2015 12:39pm
AndyKay
Dropped it off at the local LR specialist and apparently the release valve is faulty. Not releasing air. Is the valve fixable? Quick look on Disco3 mentions something about greasing the valve up?
Anyone had anything similar? Bit annoying that it could potentially mean a whole new compressor! PLUS fitting. Big Cry RRS HSE TDV6 Autobiography
Post #464384 Fri Jun 12 2015 12:21pm
Disco_Mikey
More often than not, this is a calibration issue, instead of a faulty compressor.
In fact, in all my days, I have only ever seen 1 single faulty AMK, but hundreds of poor calibrations Thumbs Up
Post #464385 Fri Jun 12 2015 12:46pm
AndyKay
Well it was in to do the calibration and they did attempt it but apparently the valve won't release RRS HSE TDV6 Autobiography
Post #464386 Fri Jun 12 2015 12:48pm
AndyKay
Is the compressor valve a separate part? I keep reading about this 'Transfer relief valve' - looks a lot cheaper than a full compressor cost RRS HSE TDV6 Autobiography
Post #464387 Fri Jun 12 2015 12:57pm
AndyKay
Quick update: it's an error in the 'venting gallery' if that helps? Is that an issue known with these AMK ones? RRS HSE TDV6 Autobiography
Post #464391 Fri Jun 12 2015 1:46pm
Disco_Mikey
That's the issue I had with mine, but the suspension wouldn't work at all until the air gallery was empty, then the compressor would kick in
Post #464407 Fri Jun 12 2015 7:34pm
