Home > Faults & Fixes > The middle vents and the rear vents are not working
MOB4LIFE
United Kingdom 2012 Range Rover Sport 3.0 TDV6 Autobiography Java Black
I'm having some issues with my climate control - top and bottom vents are all working fine, all of the middle vents and the rear vents are not working at all no air is coming out from them.
Any idea?
Post #463681 Wed Jun 03 2015 2:27pm
Blender motor failure. There will be a relevant fault code stored in the system which a decent indie or LR garage should be able to read. 2012 SDV6 - it's missing a couple of cylinders
Post #463695 Wed Jun 03 2015 6:37pm
daniellecee07
United Kingdom 2012 Range Rover Sport 3.0 TDV6 HSE Lux Java Black
I had the same problem, best bet is to take it to a garage for a diagnosis as i tried everything and wasted a fortune on fixing things that didnt need fixing so in the end i went to a place called broadfieldsgarage.co.uk they were ever so helpful and their prices are reasonable so if your near essex maybe give them a try? Good Luck with your vents as summers coming up!
Post #464222 Wed Jun 10 2015 12:04pm
MOB4LIFE
@daniellecee07 - Did they tell you what was wrong with it? and how much did you pay to get it fixed.
Post #464224 Wed Jun 10 2015 12:47pm
daniellecee07
All it was in the end was that the vents were just packing in and they kept sticking together causing them not to work such a small problem in the end. i just got all new vents fitted in, they showed me the parts i needed and i fitted them myself. Your case might be different but its definitely worth looking in to as it could be as simple as that.
Post #464227 Wed Jun 10 2015 1:35pm
