![]() | Home > Faults & Fixes > The middle vents and the rear vents are not working |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9013 ![]() ![]() ![]() |
Blender motor failure. There will be a relevant fault code stored in the system which a decent indie or LR garage should be able to read. 2012 SDV6 - it's missing a couple of cylinders
daniellecee07 Member Since: 10 Jun 2015 Location: essex Posts: 2 ![]() ![]() ![]() |
I had the same problem, best bet is to take it to a garage for a diagnosis as i tried everything and wasted a fortune on fixing things that didnt need fixing so in the end i went to a place called broadfieldsgarage.co.uk they were ever so helpful and their prices are reasonable so if your near essex maybe give them a try? Good Luck with your vents as summers coming up! |
MOB4LIFE Member Since: 23 Mar 2015 Location: London Posts: 17 ![]() ![]() ![]() |
@daniellecee07 - Did they tell you what was wrong with it? and how much did you pay to get it fixed. |
All it was in the end was that the vents were just packing in and they kept sticking together causing them not to work such a small problem in the end. i just got all new vents fitted in, they showed me the parts i needed and i fitted them myself. Your case might be different but its definitely worth looking in to as it could be as simple as that. |
