Home > General > Access mode.
designboy
United Kingdom 2007 Range Rover Sport TDV8 HSE Lux Stornoway Grey
Access mode.
With 22" wheels it wont lower with the size of it.
Post #462807 Sun May 24 2015 6:32pm
Height sensor playing up by the sound of it. When you try it do you get any red lines showing on the 4x4 display? Will it raise to off road height using the buttons? 2012 SDV6 - it's missing a couple of cylinders
Post #462851 Mon May 25 2015 7:59am
designboy
Intersting
Post #462882 Mon May 25 2015 3:15pm
The sensors are at on the inner face of the wheel well. You should see the arm and connecting rod quite easily. If you need to change one then you'll also need a calibration doing - can be done DIY with an IID Tool or by someone with another suitable system e.g. LR dealership. 2012 SDV6 - it's missing a couple of cylinders
Post #462883 Mon May 25 2015 3:55pm
designboy
Cheers, so one of these will do the job (if its broken)
http://www.ebay.co.uk/itm/range-rover-spor...3cd53a240c
Post #462900 Mon May 25 2015 10:38pm
The rear sensors are handed - so make sure you get the correct one for the side that has failed. 2012 SDV6 - it's missing a couple of cylinders
Post #462944 Tue May 26 2015 5:58pm
