Home > General > IID Tool in Colchester - Essex
pots1968
United Kingdom 2013 Range Rover Sport SDV6 HSE Santorini Black
This may seem stupid question ... but ....
I have 2010 RRS HSE 3.0TDV6 .... can I activate the auto heating if someone has access to IID tool ..
also what other tweaks / fixes would ... or maybe available to my bus ... and then the crunch question ...
anyone in or around colchester area able to assist .... ?
costs etc ...
hopefully
Bow down
Post #461864 Wed May 13 2015 8:44pm
Bodsy
Site Sponsor
Yes you can activate it Thumbs Up
Can't activate that much more than your hse has already.
Timed climate
Remote climate (same as above but with additional hardware)
Beep on lock/unlock
Heated steering wheel enable (if you add a heated steering wheel, may also need clock spring)
Towing electrics
Read/reset fault codes
Reset/calibrate gearbox/transfer box
Check fbh working, purge as required
There's other bits it can enable, but you'll need additional modules for them.
Drop me a PM with your postcode as I'm out Cambs way soon. Thumbs Up
Ian Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #461888 Wed May 13 2015 11:24pm
