Home > Technical > Temp Gauge Behaviour
Landyrover
Hi All,
I've recently acquired a 2007 TDV6 HSE RRS. One thing I've noticed is the temp gauge doesn't budge until after about 20 minutes driving, it then hesitatingly goes to point to the mid-position where it sits, as expected.
The temp sensor was swapped over for a new one today but on starting the car this evening the problem hadn't been resolved.
No other symptoms. Just had major service, no fault codes relating to this, no other symptoms I'm aware of.
Any ideas? I'm thinking new thermostat but I'm no expert!
Cheers,
Nick
Post #461851 Wed May 13 2015 6:38pm
shakeapaw
mine does exactly the same, and has done for the past 4 years, why do you think it is faulty? 07,TDV8,Black, Black Heated leather all round, Rear Entertainment with Headpones & Remote, TV, DVD, Pure Dab Digital Radio, Sidesteps, Adaptive Headlights, sunroof, now working fuel burning heater Smile)))
Post #461860 Wed May 13 2015 7:26pm
Disco_Mikey
My temp gauge starts moving after around 1 mile of driving, and Upto exactly half way after 3-4 miles
Post #461868 Wed May 13 2015 8:16pm
20 minutes of driving to get up to temp does sound rather slow to me. My (admittedly different engine) TDV8 does basically as DM's does. It's quicker still if the ambient temp is low because the FBH kicks in and helps. 2012 SDV6 - it's missing a couple of cylinders
Post #461873 Wed May 13 2015 8:38pm
Gornal Hills
United Kingdom 2007 Range Rover Sport TDV6 HSE Cairns Blue
Hi, mine does exactly as DM says but even quicker if the old FBH kicks in Thumbs Up (2007 2. Thumbs Up 2.7HSE) 2007, HSE, Cairnes Blue, Factory tints, Love it !!!
Post #461883 Wed May 13 2015 9:27pm
Landyrover
Thanks all for the responses, so it definitely sounds slower than the norm - my experience of driving Defenders and Discos is the warm up time is usually only a few mins...
Post #461889 Wed May 13 2015 11:18pm
Landyrover
FBH? Sorry to be dim Rolling Eyes
Post #461890 Wed May 13 2015 11:18pm
Russben
FBH = Fuel Burning Heater.
It's on the diesel engine RRS to help warm the engine when it's cold outside. It can also be programmed to 'fire up' at a set time to pre-heat the car ready for you.
I notice yours is a 2.7 TDV6 so it will have one fitted. If yours isn't enabled to be set to come on at a set time, one of the site sponsors can enable it for you at a very reasonable cost. Disc Mikey or Flack can certainly do this, as well as numerous others. I'm in the shed, I'll be back in the real world in a minute.
Post #461892 Wed May 13 2015 11:25pm
Landyrover
Thanks, didn't know that - obviously! Very Happy
Sounds good
Post #461893 Wed May 13 2015 11:38pm
Russben
Well worth it in winter. Pre set your time the night before & wake up to a nice warm & defrosted car Thumbs Up
It does use a bit of battery power though, but does only run for about half an hour which is sufficient.
You can also set the car to cool the interior in hot weather (not used much in UK, obviously), but this uses ambient outside air & not air conditioning, so isn't really cold.
Have a look on the multi-media screen home page to see if 'Timed Climate' is listed. I'm in the shed, I'll be back in the real world in a minute.
Post #461894 Wed May 13 2015 11:49pm
Russben
Sorry, we seem to have gone off topic Embarassed I'm in the shed, I'll be back in the real world in a minute.
Post #461895 Wed May 13 2015 11:50pm
Landyrover
Nope, can't see it listed but good to learn something new!
Soo, next stop a new thermostat I'm still thinking?
Post #461897 Thu May 14 2015 6:35am
Landyrover
Did a longer drive this morning and the needle spent most of the time at the bottom of the gauge. It found its way to the mid position a few times but then made it's way south again. Erratic is the best descriptor...
Post #461905 Thu May 14 2015 8:53am
Paddi
Landyrover - There is a 'Pressure Relief Housing' PRT.
From the manual:
"The PRT housing contains a normal thermostat, which is positioned such that the wax's temperature is controlled by both the coolant from the radiator and the bypass. This results in the thermostat being able to vary its opening temperature dependant on ambient conditions. The PRT also contains a sprung loaded valve, which limits the amount flow using the bypass. This means that the engine can run without coolant flowing through the bypass temporarily, to improve heater performance."
So perhaps try changing the whole assembly? Might be a good idea to first make sure the viscous coupled fan is not seized and running all the time so overcooling. 2008 MY Java Black TDV8 HSE
Post #461952 Thu May 14 2015 4:58pm
Landyrover
Great, many thanks for this, most helpful!
Post #461971 Thu May 14 2015 9:42pm
