Home > General > Newbie to RRSPORT With a poorly RRS
BOOM
Help needed my poor Range Rover isn't running properly it started a few days ago , I notice whilst going up a small hill black smoke the it went in to limp mode 😢. This happened around 6 times it went in to a local garage today for them to put on the diagnostic machine and fix. They have inspected all breather pipes and the thought it was the EGR so they cleaned it. But now the car is worse then before it whent in and the smoke is a lot worse ??? On the bill they've put an advisory which says The vehicle has a power link fitted which may cause over fueling and smoke when accelerating ?? Evan though this has been fitted over 2 years and never had this problem before ??? Has anybody had the same problem or any ideas what's causing this problem thanks inaddvance 😉
Post #460785 Wed Apr 29 2015 8:13pm
MG1959
Disco Mikey is your man
Post #460796 Wed Apr 29 2015 10:49pm
Camelrock
You don't say how old your car is or what engine, if an early model then I would look into blanking the EGR's then see how it performs.. 2008 G4 RRSport TDV8 current
2009 TDCi 90 current
1994 Dakar current
Post #460799 Wed Apr 29 2015 10:59pm
Scroll over the picture of the sport below his username and if it's up to date, then he has a 2008 TDV8. Thumbs Up
Boom, can't you take the powerlink off? Then see how it runs. I wasn't aware you could clean the EGR's I thought you had to replace them, not clean them. Confused Where did you take it for diagnosis?
Post #460810 Thu Apr 30 2015 8:22am
Bodsy
Site Sponsor
Have the intercollegiate pipes been checked for splits or delamination? That's the usual cause of that Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #460811 Thu Apr 30 2015 9:06am
Another thing to check would be the actuator arm on your turbo(s).
My old TDV8 did it when bowling up a steep hill... limp mode the lot.
The problem was solved by removing the BAS map.
Pete (BAS) felt a sticky actuator arm coupled with the sustained maximum boost was the probable cause. RRS gone
Post #460825 Thu Apr 30 2015 11:44am
BOOM
Thanks for the replies Very Happy I rang the garage today and they have confirmed that they haven't checked the pipes as of yet and they thought a quick spray of EGR cleaner would clear the problem as the EGR was blocked ???..so there next step is to check the pipes as anybody got any links which will show me which pipes to check as they can't see my car until next Wednesday Wink here's my year and engine size Range Rover Sport TDV8 on a 2008 plate......
Post #460863 Thu Apr 30 2015 3:52pm
shakeapaw
just lift the bonnett up and look down, they are two identical pipes running from the fron of the vehicle into the engine, remove these black rubber pipes and inspect them, it takes less then 5 minutes and replacement ones cost around £20/30 each at a indie, more from a main dealer, if one has perished, then replace them both 07,TDV8,Black, Black Heated leather all round, Rear Entertainment with Headpones & Remote, TV, DVD, Pure Dab Digital Radio, Sidesteps, Adaptive Headlights, sunroof, now working fuel burning heater Smile)))
Post #461041 Sun May 03 2015 9:30am
