Home > Maintenance & Modifications > Rear Brakes |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4403 |
I believe (but stand to.be corrected) That the light comes on at 2mm. However, there are only 2 sensors to monitor 8 brake pads.
Wed Apr 29 2015 6:54pm |
steverrs Member Since: 17 Feb 2011 Location: West Lothian or somewhere abroad Posts: 98 |
Mikey, Thank you for your as always accurate response. I will probably replace the discs as well as they do seem a bit corroded as the vehicle does sit for long periods. Due back in June so will drop you a PM. |
Thu Apr 30 2015 5:34am |
