Home > Maintenance & Modifications > Front suspension not rising |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8976 |
There is a valve block next to the compressor. This sends air front and rear so be worth checking it too. 2012 SDV6 - it's missing a couple of cylinders
Tue Apr 21 2015 7:21am |
Sandychris Member Since: 20 Apr 2015 Location: Highlands Posts: 13 |
Thanks i will have a look at that cheers |
Tue Apr 21 2015 8:41am |
Both valve blocks stripped and rebuild ,still no joy with the front suspension dash says rising constantly and back still going up and down no prob ..... Any suggestions |
Wed Apr 22 2015 9:16pm |
When you changed the compressor did you change the relay too? Not sure it makes a difference but it is one of those "you must do" things.
Wed Apr 22 2015 9:59pm |
Waiting for the relay to come 7 day delivery .....that's the problem with the highland it's too far from anywhere will give that a go and see where I go from there I have a mate with a link up so will see if any codes come up |
Thu Apr 23 2015 9:57pm |
There are a couple of relays that are the same in the fuse box so swapped them over but suspension still not playing , I am planning to swap the front and rear valve block to see if the problem goes to the rear? Anybody don't this before? Are the valve blocks the same? They look the same..... Local (120miles away) dealer have no relays so waiting for ebay one to arrive before I can swap, |
Sat Apr 25 2015 10:05am |
The valve blocks are not the same. If you have a rear valve block at the front then this might cause a problem.
2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Sat Apr 25 2015 11:34am |
Don't have the valves swapped just thought it might be worth a go to see if the front raises, but if they are not the same its prob not worth doing , just to re clarify the front just stopped rising a few weeks after changing the compressor |
Sat Apr 25 2015 2:40pm |
If the front doesn't rise at all that suggests, to me at least, either a problem with the reservoir valve block or the pipe between it and the front valve block. Something is preventing air getting to the front valve block. Are there any errors showing (either a light on the dash, a dash message or error codes stored)? It's possible that some dirt got in to the pipework and has caused a blockage.
Sun Apr 26 2015 12:36pm |
UK Guy Member Since: 28 Nov 2010 Location: Staffs Posts: 149 |
I had a very similar issue on my 06.
Sun Apr 26 2015 4:45pm |
Fbh? |
Sun Apr 26 2015 8:34pm |
Relay arrived at long last and its the wrong one arrrggg , so got my old one off and got it checked and every thing seems fine with it, i will take the valve blocks off again and see if anything look obviously wrong, has anyone changed the compressor valve block supply line to the front and back before, but its only one valve so i dont see how it will affect the front only??, is there any other valve blocks hidden away anywhere?? |
Wed Apr 29 2015 5:39pm |
,Fuel burning heater, RRS HSE with a few extras & a 2013 RRS Autobiography |
Wed Apr 29 2015 9:56pm |
Thanks for all the help so far this is where I am now .......Front crossover valve replaced and still the same issue, back goes up no probs and the fron struggles and the dash is saying rising slowly , then will go into extended , then shuts down and give the suspension error 30mph max , have had all valves off and cleaned checked they worked thought there was an issue with the front valve set as the crossover valve felt a bit sticky and was taking 4.6 volts to energise it , so far new pump and new front crossover valve .... Anyone got any suggests where to go from here |
Sat May 09 2015 8:54pm |
