![]() | Home > Maintenance & Modifications > Front suspension not rising |
gazzc Member Since: 07 Jan 2010 Location: cheshire Posts: 494 ![]() ![]() |
just spoken to my pal that gave me a hand to fit turbo and he reckons that front was not rising as well so worth checking the height sensors if you have been near them silverRRS 2.7 TDV6 22"WHEELS FULL COLOUR CODE,STEPS,REMAP..gone
Sandychris Member Since: 20 Apr 2015 Location: Highlands Posts: 13 ![]() |
Just managed to get the truck onto a computer and its saying C1A20 pressure too slow increase upon tank filling up 5A20 and C1130 pneumatic spring air supply 5130 and C1130 pneumatic spring air supply so three codes coming up with two the same ??
Job done , small air leak in the front left strut, new strut fitted and all is well.....at last |
w55ksy Member Since: 05 Feb 2015 Location: Bromley Posts: 7 ![]() ![]() ![]() |
Sandychris,
Sorry not been on line for ages, but I heard a slight whisper and the plugged the offending shock at the crossover valve and all the other shocks ping into action,
Ok the suspension pump is coming up with an over temp error and on computer its registering 98deg ........any suggestions to clear this fault ??? |
