Home > Technical > Steering wheel vibrates when I brake
Andyjay123
As above, when braking slowly doing 30-70mph or anywhere in between the steering wheel vibrates
Any ideas?
Thanks 2006 RRS Supercharged 4.2 HST muthuaflecka!
Post #459783 Sun Apr 19 2015 5:50pm
Lost for Words
Warped discs? Visiting from DISCO3.CO.UK
Post #459785 Sun Apr 19 2015 5:53pm
iforland
This could be warped discs, any good garage will be able to confirm this. Unfortunately it would require new discs and pads.
Post #459786 Sun Apr 19 2015 5:54pm
Paddi
Re: Steering wheel vibrates when I brake
Any ideas?
Thanks
Did you by any chance have the discs and pads replaced about a thousand miles ago?
Most likely you have excess runout on one or both discs. You could have the discs skimmed but it needs to be done by a specialist. Find one using this link: http://www.skimmydiscs.co.uk/find-your-nearest-service-centre/ 2008 MY Java Black TDV8 HSE
Post #459849 Mon Apr 20 2015 12:31pm
Andyjay123
Warped discs and worn down pads! oooops! £2000+ 2006 RRS Supercharged 4.2 HST muthuaflecka!
Post #460254 Thu Apr 23 2015 3:56pm
Lost for Words
Quote:
£2000+
What!? Confused Exclamation Visiting from DISCO3.CO.UK
Post #460255 Thu Apr 23 2015 4:11pm
Andyjay123
hah ok it ended up being £967 for all 4 wheels disks and pads 2006 RRS Supercharged 4.2 HST muthuaflecka!
Post #460269 Thu Apr 23 2015 6:37pm
Lost for Words
What callipers?
At that price, am I to take it you have 6-pot Brembos? Visiting from DISCO3.CO.UK
Post #460274 Thu Apr 23 2015 6:55pm
Russben
Try Advanced Factors (one of the forum sponsors). They list a Borg & Beck kit of discs & pads (including bolts etc) for £109. It's easy enough to do yourself and should only take a couple of hours.
http://www.advancedfactors.co.uk/001a-disc...4882-p.asp I'm in the shed, I'll be back in the real world in a minute.
Gone- 2010 TDV6; Hello 2017 SDV6.
Post #460321 Fri Apr 24 2015 11:15am
Lost for Words
Since Andyjay123 has been looking for a video of a performance exhaust on a 3.0, I suspect those are the one type of brakes it's safe to assume he probably doesn't have. Wink
The sentiment still applies though. Thumbs Up Visiting from DISCO3.CO.UK
Post #460325 Fri Apr 24 2015 12:00pm
