![]() | Home > Technical > Steering wheel vibrates when I brake |
Warped discs? Visiting from DISCO3.CO.UK
iforland Member Since: 13 Apr 2015 Location: Redditch Posts: 47 ![]() ![]() |
This could be warped discs, any good garage will be able to confirm this. Unfortunately it would require new discs and pads. |
Did you by any chance have the discs and pads replaced about a thousand miles ago? Most likely you have excess runout on one or both discs. You could have the discs skimmed but it needs to be done by a specialist. Find one using this link: http://www.skimmydiscs.co.uk/find-your-nearest-service-centre/ 2008 MY Java Black TDV8 HSE ![]() |
Andyjay123 Member Since: 22 Aug 2014 Location: London Posts: 698 ![]() |
Warped discs and worn down pads! oooops! £2000+ 2006 RRS Supercharged 4.2 HST muthuaflecka! |
What!? ![]() ![]() 2006 Discovery 3 TDV6 Auto HSE Zambezi Silver ![]() |
hah ok it ended up being £967 for all 4 wheels disks and pads 2006 RRS Supercharged 4.2 HST muthuaflecka! |
What callipers?
Russben Member Since: 27 Mar 2013 Location: Lancashire Posts: 278 ![]() ![]() |
Try Advanced Factors (one of the forum sponsors). They list a Borg & Beck kit of discs & pads (including bolts etc) for £109. It's easy enough to do yourself and should only take a couple of hours.
Since Andyjay123 has been looking for a video of a performance exhaust on a 3.0, I suspect those are the one type of brakes it's safe to assume he probably doesn't have. |
