Home > Technical > Suspenion Problem after rebuilding compressor |
gazzc Member Since: 07 Jan 2010 Location: cheshire Posts: 494 |
i had the same problem ,i found that were the pipes went into my rebuilt compressor they were slightly leaking,i ended up cutting about 5mm off the pipe and refitting it and all was fine,apparently the reason these compressors wear out is due to leaks ,did you find the leak and sort it before refitting compressor silverRRS 2.7 TDV6 22"WHEELS FULL COLOUR CODE,STEPS,REMAP..gone
Mon Apr 20 2015 6:26pm |
RobH69 Member Since: 24 Sep 2014 Location: Dublin, Ireland Posts: 11 |
brilliant I'll try that in the morning, I never spotted any leaks beforehand.
Mon Apr 20 2015 7:58pm |
doesn't seem to be any leaks and now after jumping the relay, it is coming up with the suspension fault message as soon as you turn the ignition, any more ideas? |
Tue Apr 21 2015 11:14am |
couldn't find a leak but ended up cutting the pipes anyways as I had ran out of options and it's fixed it, thanks very much really appreciate the advice mate! |
Tue Apr 21 2015 11:06pm |
great stuff,glad its fixed,the leak on mine was very small,i went around all my pipes with gas leak test spray and found the original leak which caused my compressor failure..was a small union on top of rear airbag liking slightly making comp run for to long and burn out silverRRS 2.7 TDV6 22"WHEELS FULL COLOUR CODE,STEPS,REMAP..gone
Wed Apr 22 2015 5:47am |
