Home > Maintenance & Modifications > Can anyone lower my car for ££
Andyjay123
Want it lowered by 20mm Smile 2006 RRS Supercharged 4.2 HST muthuaflecka!
Post #459430 Thu Apr 16 2015 9:54pm
D12TYJ
United Kingdom 2012 Range Rover Sport SDV6 HSE Buckingham Blue
+1 Cool
Post #459434 Thu Apr 16 2015 10:17pm
Just buy some lowering links from ebay (or where ever). Then you can easily revert to standard if you need to. Less than £100 from what I can see. 2012 SDV6 - it's missing a couple of cylinders
Post #459439 Thu Apr 16 2015 11:19pm
johnunleashed
2007 Range Rover Sport Supercharged HST Java Black
http://www.ebay.co.uk/itm/RANGE-ROVER-SPOR...0986724993 2007 SUPERCHARGED HST
Post #459447 Fri Apr 17 2015 7:03am
darrenmcneill
England 2006 Range Rover Sport TDV6 HSE Tonga Green
Anybody used these? 2006 HSE for Sale - £7,499 (Manchester)
http://www.rrsport.co.uk/forum/topic46383.html
Post #459581 Fri Apr 17 2015 9:28pm
D12TYJ
Leaning towards these but as above would like some feedback from fellow members first.
Fairly cheap enough, and doesn't seem that hard to do, think a quick easy DIY job these.
Post #459582 Fri Apr 17 2015 9:33pm
Lost for Words
I'd leave the height as it is. It'll make naff all difference to the handling and will just spoil the ride.
You should have a full alignment if you do have it lowered or you'll find your tyres wearing unevenly etc. Thumbs Up Visiting from DISCO3.CO.UK
Post #459617 Sat Apr 18 2015 8:48am
I think lowering is about the look of the car, not whether it improves the ride/handling in any measurable way.
The few times this has been brought up on the forum, the usual answer is that it makes the ride overly firm and bouncy. Also it prevents the use of access height - the car will bottom out and then go in to extended mode instead.
My own view is that if you're going to look to lower the car, do it using one of the electronic systems. Yes, they're more expensive but they allow you to fine tune the system and you can change heights at the touch of a button without getting wet/dirty in the wheel arches. Thumbs Up
Whatever system you use you'll need to factor in an alignment check - bear in mind that you'll probably only be able to adjust the toe of the wheels - being lowered will change the camber and it might be outside of the camber nut's ability to compensate. 2012 SDV6 - it's missing a couple of cylinders
Post #459625 Sat Apr 18 2015 10:21am
Lost for Words
Ahh, right, didn't think of that but, IMO, the same applies. Horses for courses, I suppose. Visiting from DISCO3.CO.UK
Post #459630 Sat Apr 18 2015 10:34am
Yes, I think the lowered 4x4 look is ridiculous Whistle but they say it takes all sorts to make a world... Rolling with laughter 2012 SDV6 - it's missing a couple of cylinders
Post #459640 Sat Apr 18 2015 11:50am
