Home > General > Transmission Leak? Approximate Cost? |
darrenmcneill Member Since: 05 Oct 2014 Location: Whitworth Posts: 442 |
Afternnon,
Wed Feb 18 2015 2:41pm |
FatJoe Member Since: 13 Dec 2014 Location: Staffordshire Posts: 259 |
If you have the 2.7 v6 diesel engine it could be a leak from the electrical plug. Very common on the disco forum. Theres a replacement seal for it which is £8. Plug pops out, change seal and pop it back in. Identify where the leak it coming from first. I'm not Fat. RRS TDV6 HST. |
Wed Feb 18 2015 5:55pm |
Advanced Factors Site Sponsor Member Since: 26 Apr 2013 Location: Southampton Posts: 287 |
The main wiring loom to Mechatronic seal is common but it's a bit more than "Popping it out" you will need to drop the transmission sump, release the internal clip and then change the seal from the outside, be very careful as the electrical pins are easy to damage.
Thu Feb 19 2015 8:35am |
Took the car to a ger box specialist that I have used in the past on my previous BMW.
Wed Apr 15 2015 11:17am |
What seal?
Wed Apr 15 2015 2:06pm |
Couchnomad Member Since: 07 Jan 2015 Location: Staffs Posts: 19 |
Hi 'FatJoe'
Wed Apr 15 2015 2:11pm |
Not 100% sure tbh, to access it the driveshaft is in the way and needs moving? I should have paid more attention really shouldn't I? I was busy going through numbers in my head! 2006 HSE for Sale - £7,499 (Manchester) http://www.rrsport.co.uk/forum/topic46383.html |
Wed Apr 15 2015 4:17pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8982 |
Bear in mind that the item in the pictures appears to be the transfer box, not the gearbox itself. 2012 SDV6 - it's missing a couple of cylinders
Wed Apr 15 2015 4:53pm |
Could be the gearbox?? Just know that it's not easy to get to?
Wed Apr 15 2015 4:58pm |
It's the transfer box and has several oil seals (input shaft from the gearbox, output shaft going to the front diff, output shaft to the rear diff). All of them require the transfer box to be removed from the vehicle, I believe, and some require the box opening up. 2012 SDV6 - it's missing a couple of cylinders
Wed Apr 15 2015 5:49pm |
Sounds like that one then. Im guessing without knowing it would be hard to establish if my price was reasonable?
Wed Apr 15 2015 7:12pm |
Hi Darren, I use a place called Weston Autocentre in Bridgtown just off the A5. A guy call Chris works on them. Theyve done my cars for years but I didn't realise he'd worked on these beasts before so now I know I've continued taking it there. They are reasonably priced. Recently had the big service their too with all belts including the back fuel pump. I'm not Fat. RRS TDV6 HST. |
Wed Apr 15 2015 8:46pm |
