Home > Technical > Low level of motor oil after couple thousands of kilometers
RRSCS
Hungary 2010 Range Rover Sport 3.0 TDV6 Autobiography Santorini Black
Hi Folks,
My 2.7 TDV6 has around 190K kilometers and recently seems to have started to 'eat up' the motor oil. Since the latest service (oil change in every 12K kilometers) I ran approx. 6K kilometers and the oil level went down to close to minimum. I had white smoke on cold starts in couple of mornings (2-4 times) so I went to my LR specialist to check. The indi found nothing irregular, except the low oil level so topped it up, but after 2K kilometers it went down again to the level of 1/4 Big Cry . I never had to top up oil before, and always kept the service intervals rigorously, even earlier sometimes. I guess it can be a turbo issue, but before I put it into the indi's hand, I wanted to ask whether anyone has any idea, experience? Thanks in advance. Cheers,
Post #458766 Fri Apr 10 2015 3:34pm
RRSCS
Hi There,
Anybody, any idea pls Bow down
Post #458998 Mon Apr 13 2015 6:19am
frostmotorsport
New Zealand 2006 Range Rover Sport Supercharged Rimini Red
That is a fair bit of oil use. My first guess (assuming it's not leaving big puddles in your driveway or on your garage floor) is the turbo seals - they're pretty common points of oil egress on higher mileage vehicles - which yours is tbh.
The other place to look is in the intake piping - if it's a piston-ring issue you might find your intake pipes all oily.
Do you know someone who can do a compression test (or pref. a leak-down test) ? Every home should have one!
'06 RRS SC Rimini Red
'04 Audi S4 Avant
Escort Mk II Sport
Post #459011 Mon Apr 13 2015 9:27am
RRSCS
Dear frostmotorsport,
thanks a lot, much appreciated. Will share this with indi and get it checked.
Cheers,
Post #459013 Mon Apr 13 2015 9:51am
