Home > Technical > Fault code can anyone help
madmackie
United Kingdom 2005 Range Rover Sport TDV6 HSE Bonatti Grey
my cruise control has started playing up one minute it works then it doesn't the fault code is
P0578 speed control multi function input A circuit is stuck
I have also heard a slight squeak as the wheel is being turned can anyone advise me thanks in advance "Remember its easier to say sorry than it is to get permission " especially off the Mrs !!
Post #458723 Thu Apr 09 2015 8:00pm
Disco_Mikey
Most likely the wiring loom behind the airbag
If not, then the switch pack
In very limited cases, the clock spring loom can break
The wiring loom and switch pack are around £60 brand new, or the loom.on its own for £20 or so, and is where I would be starting Thumbs Up
Post #458726 Thu Apr 09 2015 8:35pm
madmackie
thanks disco sent you a pm "Remember its easier to say sorry than it is to get permission " especially off the Mrs !!
Post #458728 Thu Apr 09 2015 8:42pm
