Home > Maintenance & Modifications > Front and rear diff and transfer box fluid chamge
Crinny84
Just wondering how big a job this is and what sort of price from a decent speacialist
Post #458590 Wed Apr 08 2015 4:10pm
Mister B
United Kingdom 2006 Range Rover Sport TDV6 HSE Bonatti Grey
Hi had my front and rear diff fluids changed by local indie and was £160 from memory
HTH
Post #458601 Wed Apr 08 2015 6:41pm
Dan Stevens
Australia 2006 Range Rover Sport TDV6 SE Zermatt Silver
Do it yourself it's really easy.
I did mine.... didn't take long at all. I bought my fluids from a landrover indie and set to it in the garage.
You Don't even need ramps if you put the vehicle in off-road mode.
i even did my gearbox..... check the pic it was a little overdue
Whistle Whistle Whistle Whistle
Post #458644 Thu Apr 09 2015 5:49am
Crinny84
Been quoted 250 for front and rear diff and transfer box!
Post #458647 Thu Apr 09 2015 6:39am
Crinny84
Thinking of doing this myself. My car is an 07 v8 supercgarger. Could anyone please tell me how much fluid I will need for front/back diff (I no these are both different fluids, and I'm prity sure mine has the locking rear diff) and also for the transfer box. Do I need to buy new drain plugs or are the old ones sufficient? And does each one have to be torqued up to certain setting? And I believe this is a fill till spill on all three. Thanks
Post #458648 Thu Apr 09 2015 7:01am
Lost for Words
Dan, that's not the correct ATF - it shouldn't be red. Exclamation Wink Visiting from DISCO3.CO.UK
Post #458661 Thu Apr 09 2015 9:35am
frostmotorsport
New Zealand 2006 Range Rover Sport Supercharged Rimini Red
Nope. Front is Castrol SAF XO (or similar non-LSD 75-90 fluid) and requires 0.61 litres which is not up to the fill hole.
see how-to here: http://www.disco3.co.uk/forum/topic32281.html
Obviously ignore the bit about the fuel filter change! This has front & rear diff oil change info and good pics. Every home should have one!
'06 RRS SC Rimini Red
'04 Audi S4 Avant
Escort Mk II Sport
Post #458684 Thu Apr 09 2015 1:41pm
