Home > Maintenance & Modifications > Front and rear diff and transfer box fluid chamge |
Mister B Member Since: 25 Apr 2014 Location: South West Posts: 179 |
Hi had my front and rear diff fluids changed by local indie and was £160 from memory
Wed Apr 08 2015 5:41pm |
Dan Stevens Member Since: 19 Aug 2013 Location: Brisbane Posts: 47 |
Do it yourself it's really easy.
Thu Apr 09 2015 4:49am |
Crinny84 Member Since: 22 Oct 2014 Location: Manchester Posts: 18 |
Been quoted 250 for front and rear diff and transfer box! |
Thu Apr 09 2015 5:39am |
Thinking of doing this myself. My car is an 07 v8 supercgarger. Could anyone please tell me how much fluid I will need for front/back diff (I no these are both different fluids, and I'm prity sure mine has the locking rear diff) and also for the transfer box. Do I need to buy new drain plugs or are the old ones sufficient? And does each one have to be torqued up to certain setting? And I believe this is a fill till spill on all three. Thanks |
Thu Apr 09 2015 6:01am |
Lost for Words Member Since: 15 Jan 2015 Location: Warminster, Wiltshire Posts: 1477 |
Dan, that's not the correct ATF - it shouldn't be red. Visiting from DISCO3.CO.UK 2006 Discovery 3 TDV6 Auto HSE Zambezi Silver |
Thu Apr 09 2015 8:35am |
frostmotorsport Member Since: 14 Apr 2014 Location: Wellington Posts: 79 |
Nope. Front is Castrol SAF XO (or similar non-LSD 75-90 fluid) and requires 0.61 litres which is not up to the fill hole. see how-to here: http://www.disco3.co.uk/forum/topic32281.html Obviously ignore the bit about the fuel filter change! This has front & rear diff oil change info and good pics. Every home should have one! '06 RRS SC Rimini Red '04 Audi S4 Avant Escort Mk II Sport |
Thu Apr 09 2015 12:41pm |
