Home > General > Pitching on bumpy/wavey road
Timf
United Kingdom 2010 Range Rover Sport TDV8 HSE Galway Green
Hi all, a quick question...I was doing a bit over the speed limit Embarassed yesterday on the A120 round Braintree Essex & the RRS started a rather alarming pitching from front to back. The road surface has 'waves' in it I guess, as when I was a bit further along, the ride was more level & pitching stopped. I haven't noticed it before & I had to slow down to about 60 to stop it. Was it just my speed? As I hadn't noticed it before, even at speed, I wondered if anything needs checking out. It's just passed the MOT, not that they'd have checked air suspension, I guess... Question
Post #458405 Mon Apr 06 2015 4:15pm
It's probably just a harmonic frequency thing going on. I use a stretch of the A34 every day that has expansion joints in the surface. These set up a similar slight forward/backwards pitching sensation at about 50mph. It probably just corresponds to some natural frequency in the suspension system. 2012 SDV6 - it's missing a couple of cylinders
Post #458407 Mon Apr 06 2015 4:43pm
Timf
Thanks for that RRSTDV8, mind at rest Thumbs Up
Post #458408 Mon Apr 06 2015 4:48pm
Tim in Scotland
If yours is a used car (ie you aren't the first owner) check that you still have the big resonance damper weights still attached under the car, some people remove them for some reason, but they have a purpose - to cure what you have experienced. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #458415 Mon Apr 06 2015 6:06pm
Timf
Thanks Tim, yes they're still there. Interesting to hear what they're there for Thumbs Up
Post #458417 Mon Apr 06 2015 6:31pm
