![]() | Home > General (L494) > Today's technical question............ |
Rainbow Member Since: 14 Jul 2014 Location: UK Posts: 67 ![]() ![]() |
I have something similar that was in the glove box on delivery. I believe it may be a device that allows you to refuel the car using a fuel can. It either presses away the metal cover, that pops up over over the fuel pipe to prevent an unleaded fuel nozzle from being inserted, and keeps it retained back allowing you to fill the tank through the funnel or it stops the misfuelling prevention device from triggering while you fill from the can. I think recently delivered cars must have a different misfuelling device fitted as my dealer has advised that there is no need longer any need for the misfuelling reset tool that is mentioned in the current MY15 manual. |
Hugh Haddow Member Since: 03 Jul 2009 Location: Prestwick Posts: 202 ![]() ![]() ![]() |
I was advised it was for use if trying to fuel with a non standard nozzle. ie a fuel can or some eastern European filling stations.
Thanks for that, so I'd better not use it for other things and put it back in the spare wheel well just in case. I did notice that the Sainsbury's filling station nozzle I used in Stirling when I filled up was a very tight fit in the opening. Makes my usual "fill it until you can see the diesel just over the flap" constant level obsolete and I'll have to find another method 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
ilard Member Since: 20 Aug 2010 Location: London Posts: 975 ![]() ![]() |
It's a shatterproof shot glass in case you need a stiff drink after receiving the servicing bill. L405 P400e Autobiography (MY2020)... Silicon Silver / Espresso
Ten Days into ownership I have opened the owner's handbook for the first time.............. Rainbow is right, it is a special funnel to bypass the misfuelling device and allows the nozzle of a jerrycan to go down the filler. So the dealer's advice to disregard it are totally wrong, it is quite an important piece of kit. There is a description of how to use it on Page 5 of the owner's handbook supplement 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
andman Member Since: 08 Oct 2011 Location: la vella Posts: 1155 ![]() ![]() ![]() |
Penis enlarger ... clearly they forgot to give you the pump |
jimbg Member Since: 29 Jan 2013 Location: By the River Dart Posts: 1853 ![]() ![]() |
Can he borrow yours then!! |
kieron_brown Member Since: 08 Jul 2015 Location: Oxford Posts: 1 ![]() ![]() ![]() |
hi Tim
