![]() | Home > General > Heavy black smoke on acceleration |
almost certainly intercooler pipe has a split or has delaminated. |
Bladeboy Member Since: 17 Sep 2013 Location: Benson Posts: 522 ![]() ![]() ![]() |
I had the same and it turned out to be the actual inter cooler had a split in the outer casing. Got that replaced and changed to silicone hoses while I was at it. Embarrassing smoke gone! |
D12TYJ Member Since: 01 Sep 2014 Location: London Posts: 183 ![]() ![]() ![]() |
So looks like the culprit is the intercooler pipe then,
tanloverluke Member Since: 19 Mar 2013 Location: Honiton Posts: 917 ![]() ![]() ![]() |
check it first though! Recently bought a 2007 RRS HSE TDV6 for a Pimp-My-Ride-Project.
Sorry meant to write, will be checking this and ordering it tom,
it's very simple indeed. you just need to locate the cover by the front offside wheel arch (for the TVD6 in any case), take that off to give you access to the bottom end of the pipe. Recently bought a 2007 RRS HSE TDV6 for a Pimp-My-Ride-Project.
