Home > Technical > 2006 range rover sport tdv6 gearbox/trasmission oil change?
jonesy_boys
United Kingdom 2006 Range Rover Sport TDV6 HSE Firenze Red
hi guys, im looking to change my transmission oil. just wondering if anyone has any advice on how to do it or how they've done it.
main things are how do you refill and how do you know once its full?
i know how drain the oil. thanks guys. Dean
Post #456693 Sat Mar 21 2015 6:41pm
gogsy1956
This is quite a common subject, if you do a search you will find lots of threads relating to this subject. The thing to remember is that a simple drain and refill only changes half the oil in the gearbox, a lot of people swear by a megaflush which will replace all of the old oil with new. I have had mine done and would recommend to anyone,,, go for some Dr tranny and a gearbox reset as well Thumbs Up 2010 RRS, TDV8
bali Blue / colour coded
side steps / flappy paddles
black perforated leather
22" overfinch
Post #456698 Sat Mar 21 2015 7:04pm
jonesy_boys
When you refill the oil has the car got to be level or the bottom of the tray?
Post #456858 Sun Mar 22 2015 10:31pm
gogsy1956
i would imagine the car would have to be level,,,, or near enough level 2010 RRS, TDV8
22" overfinch
Post #456871 Sun Mar 22 2015 11:29pm
Lost for Words
The transmission must be between 30 and 35 degrees to ensure the level is correct. With the engine running (or you'll get a soaking), it's fill to spill. Thumbs Up
As mentioned, a full flush is the only way to change a good percentage of the oil (a single change is only about 40%).
Dr Tranny should only be used if actually required as it could mask faults later on. Consideration should also be given before a gearbox reset depending on fault codes and symptoms present. The TCM should also be cool when this is carried out. Wink
You might like to have a read here: http://www.disco3.co.uk/gallery/albums/use...ctions.pdf Thumbs Up Visiting from DISCO3.CO.UK
Post #456884 Mon Mar 23 2015 9:44am
jonesy_boys
Ok thanks for your help. I'm gunna try and do it myself, sorry does the gearbox need to be level or the bottom of the tray? As the gearbox is running up. Thanks again.
Post #456960 Mon Mar 23 2015 8:25pm
Lost for Words
Not quite sure what you mean exactly by gearbox level or the bottom of the tray?
Keep the car on the level and you should be fine. Thumbs Up Visiting from DISCO3.CO.UK
Post #457002 Tue Mar 24 2015 10:18am
jonesy_boys
Sorry, when I come to refill the gearbox has it got to be level or have I got to jack the veichle up so the box or the bottom of the oil tray is level? Do you understand what I mean? Or do you you just refill as the vehicle is sat? Cheers dean
Post #457038 Tue Mar 24 2015 5:06pm
myfirstrrs
Car has to be level, note also that the oil temperature is important but you can search this forum for that information.
Post #457040 Tue Mar 24 2015 5:16pm
jonesy_boys
Ok, with the car level the gearbox will be running up slightly is that right? Or shall I put a level on the oil tray of the gear box and jack it up till that's level? Thank again dean
Post #457052 Tue Mar 24 2015 7:48pm
gazzc
2005 Range Rover Sport TDV6 HSE Siberian Silver
dont jack anything up mate just keep the car level Thumbs Up silverRRS 2.7 TDV6 22"WHEELS FULL COLOUR CODE,STEPS,REMAP..gone
Rimini red rrs 2.7 tdv6 steps. Full c code. Recon engine!!loved but!gone ,thank god !!
Gone rr sport supercharged. Loved but 11mpg !!!
current,triumph stag mk2...current bmw 325 sport convertible
Post #457054 Tue Mar 24 2015 7:59pm
jonesy_boys
Does anyone know an easy way of changing the transmission fluid? I've changed it but I carnt get the right amount of fluid right. It keeps dropping gears
Post #481911 Tue Dec 08 2015 9:13am
Bodsy
Site Sponsor
So, you need to get the transmission oil temp between 35 and 50 degrees. Doesn't take long to warm up.
Then with the engine running (yes, the engine running) undo the fill point on the side of the box. If fluid drains out (assuming you're on level ground) then you have too much, if t doesn't, then fill until it does. Thumbs Up Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #481912 Tue Dec 08 2015 9:29am
jonesy_boys
Hi guys I've tried everything you've all said again today but no luck. It goes up the gears fine if you boot it. But if you accelerate slowly and go up the gears it keeps jumping back and for third and forth gears:/ then the transmission fault appears on the dash board.
Post #481952 Tue Dec 08 2015 6:19pm
Lost for Words
What mileage is it at? Visiting from DISCO3.CO.UK
Post #481953 Tue Dec 08 2015 6:28pm
