Home > Technical > 2006 range rover sport tdv6 gearbox/trasmission oil change?
jonesy_boys
United Kingdom 2006 Range Rover Sport TDV6 HSE Firenze Red
95000
Post #481954 Tue Dec 08 2015 6:43pm
Bodsy
Site Sponsor
Sounds like th mechatronic unit in the gearbox then..... Might be sticky valves in it. Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #481968 Tue Dec 08 2015 8:30pm
jonesy_boys
:/. Where about is it located? Can I get to it to check it out?
Post #481971 Tue Dec 08 2015 8:47pm
Bodsy
Site Sponsor
It's in the gearbox. You have to remove the gearbox pan and then the whole mechatronic unit is exposed. Nothing that I know of that you can do to check it as such. One I'd leave to the transmission specialists at that stage I'm afraid. Bodsys Brake Bible
See it HERE
Post #481978 Tue Dec 08 2015 9:26pm
Jaggs
Was it ok before you dropped the oil. Seems you may have caused more harm than good with the change, I'm no expert but I understand they are sensitive to correct grade / quantity of oil etc
Post #481979 Tue Dec 08 2015 9:32pm
