Home > Maintenance & Modifications > Water free coolant...
Gaz
England 2007 Range Rover Sport TDV6 HSE Stornoway Grey
Hey guys!
Have any of you out there switched over from using water and additive to the waterless coolant?
It obviously has benefits of not causing corrosion and having a lower freeze point and higher boiling point.
Can RRS's benefit from this?
Gaz. I was born with a photographic memory. Shame it didn't develop!
".....do you boys know what the word Nemesis means?...."
2007 2.7 TDV6 in Stornaway Grey.
EGR Blanked.
Re-mapped by Alive Tuning.
Post #456592 Fri Mar 20 2015 9:55pm
Paulcp
2013 Range Rover Sport SDV6 HSE Atacama Sand
A bit of info for you
http://www.norosion.com/evanstest.htm
Post #456636 Sat Mar 21 2015 9:03am
Gaz
.....I started disliking it after reading that the cylinder head could run hotter!!
Forget that then! Thumbs Up I was born with a photographic memory. Shame it didn't develop!
EGR Blanked.
Post #456689 Sat Mar 21 2015 5:14pm
