![]() | Home > Maintenance & Modifications > Gearbox flush in south wales. has anyone done it! |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4447 ![]() ![]() ![]() |
If you have a genuine, mechanical gearbox fault, a flush is likely to finish off the gearbox...
As DM says |
Williamsboy Member Since: 31 Dec 2014 Location: south wales Posts: 44 ![]() ![]() ![]() |
Hi Guys thanks for your replies, just had timing belts and engine oil change done ( picked her up at 5pm tonight) and on test drive they noticed she was not changing gear as she should be. They checked for fault codes but nothing showing up. This was at a local independant land rover specialist.
Brake bulbs and brake pedal switch would be first port of call |
Low fluid level also has a similar effect. |
RRS booked in for mega flush next week, checked the oil and it is almost black. Will have a look at the brake light switch as well. Both Brake light bulbs replaced recently.
Hamner Member Since: 28 Jan 2015 Location: Swansea Posts: 54 ![]() ![]() |
hi just picked up on your thread on 20 th match i live in swanse and looking for a mega flush, how did you get on ,did it make a differance and if you dont mind what was the cost many thanks danny |
Hi Hamner the Mega flush/ gearbox service that i had done did make a difference to the gear change, but i have had the Fault 'limited gears available' since the oil change. The Gearbox service was more than just a flush as they also changed the Oil pan and filter and was not cheap at £450. If you just want a flush and you are not getting the Gearbox fault as i have been having, then yes i would go for the Mega flush. The gear change improvement was noticeable from pulling away from the Garage.
thanks for your reply , i will give the guys at barry a call cheers hamner |
Hi Danny here is their number 01446 327007 and 08000337092.
Here is their website address as I forgot to put in the message above.
hi mike ,cheers for the help i like the look of your rrs nice colour and wheels ,did you get the niggles sorted in the end . mines a tdv6 in silver hse 2005 i havent worked out how to up load any pictures yet , thanks again danny |
Hi Danny I have now fitted a new brake light switch to try and sort out my gearbox fault, need to get fault codes checked and erased and maybe re
RogerDeFlor Member Since: 28 Mar 2015 Location: Gloucester Posts: 51 ![]() ![]() ![]() |
Before you spend any money on a "gear box fault", have a read of this sticky -->
