![]() | Home > Maintenance & Modifications > tailgate struts |
zaphod Member Since: 16 Jan 2015 Location: Liverpool Posts: 290 ![]() ![]() ![]() |
Got the exact same problem - mine just don't seem to have enough oomph to lift the tailgate up so if I don't remember to raise the tailgate to it's full extent manually I keep |
martyn05 Member Since: 13 Feb 2014 Location: Derby Posts: 324 ![]() ![]() ![]() |
Replaced both of mine last year, got them from http://www.sgs-engineering.com
Simon73 Member Since: 20 Apr 2014 Location: Lichfield Posts: 23 ![]() ![]() ![]() |
I got mine replaced but still heavier than I'd have expected |
That's interesting Simon, so even with new struts the tailgate won't open fully under its own stream then? |
mnk Member Since: 25 Nov 2013 Location: United Kingdom Posts: 231 ![]() ![]() |
I have sent SGS-Engineering an email asking for their recommendation on a uprated strut, I will update the thread as soon as I receive a response. |
No it needs a hand, not a lot but on its own it would probably lift about 2 foot |
Thanks, sounds like my struts are working absolutely perfectly in that case! |
Bob. Member Since: 02 Feb 2009 Location: SWest Posts: 275 ![]() ![]() |
The sub woofer mounted in the RH side adds considerably to the weight I expect. Genuine LR struts are different part numbers for each side, probably to allow for the unbalanced weight side to side. I doubt that aftermarket suppliers will allow for this and will supply the same rating for both sides. I find that the struts give less help in cold conditions.
Nsp1 Member Since: 01 Sep 2014 Location: Manchester Posts: 96 ![]() ![]() ![]() |
There's a Sub woofer in the boot?!?
Barryp Member Since: 05 Nov 2011 Location: Sydney Posts: 261 ![]() ![]() ![]() |
You will only hear it with a decent sound input which includes the required low frequency input.
simbad111 Member Since: 10 Feb 2014 Location: wolverhampton Posts: 114 ![]() ![]() ![]() |
The strut part numbers are different one is BHE790054 and the other is BHE790044, Not sure why unless its to do with the weight of the speaker in rear hatch, But would like to know how much difference |
CDS Member Since: 21 Sep 2011 Location: Oldham Posts: 25 ![]() |
SGS are very helpful, if you give them the original part numbers I'm sure they will supply an 'odd' pair of uprated ones:thumbsup: |
duckworthparts Site Sponsor Member Since: 13 Mar 2009 Location: Market Rasen Posts: 674 ![]() ![]() |
its because they are handed Sophie Alltoft Send a paypal payment direct using this link www.paypal.me/duckworthparts www.duckworthparts.co.uk My Direct Line: 01673 849873 Email: danroberts@duckworthlandrover.co.uk Supplier of Genuine Land Rover & Jaguar Parts For All Models Can also supply OEM & Aftermarket parts ![]() |
can you give me a price please on both part numbers please
