Home > Maintenance & Modifications > Car passed MOT but …...
martyn05
Hi all,
My 2006 RRS SC passed its MOT yesterday at the indie I use but they put an advisory on the certificate stating that the nearside and offside front to rear brake pipes were slightly corroded.
They said it would cost about £300 to supply and fit new ones, does this sound about right for the work and parts involved? They also said that I could clean them up and grease them.
Has anyone else had the brake pipes renewed and what was the cost?
Thanks in advance. 2006 RRS SC Bonatti Grey (the 55th car/van I have owned)
2005 GSX 1400 K5
Post #451090 Tue Feb 03 2015 3:07pm
tanloverluke
I had that on an advisory 2 years back. I fixed the problem with a wire brush. Sailed through the subsequent MOT.
Not saying that you don't have a problem, but check to make sure that they are "corroded". Recently bought a 2007 RRS HSE TDV6 for a Pimp-My-Ride-Project.
DONE: Meduza front bumper, AB rear bumper, AB tailpipes, calipers repainted, rear upper tailgate upgrade, side steps, AB front grille, AB side vents, rear LED lights, clear side repeaters, integrated daytime running lights, LED headlights.
TO DO: color code sills and pillars.
Post #451106 Tue Feb 03 2015 4:43pm
simon645
United Kingdom 2011 Range Rover Sport 3.0 TDV6 HSE Stornoway Grey
Common thing put on mot sheet, usually clean and wax oil and the job a good one
Post #451141 Tue Feb 03 2015 9:02pm
Stuart
I used to have tested a lot of Class 7 commercial vehicles at one time, and some testers love this one. If they are deeply crusty and liable to spring a leak, maybe, but a bit of surface rust is often enough for a tester to call them corroded when they are alright really.
The simple fix that we used to do is usually to clean them up with a circular wire brush on a drill or some sandapaper, then lightly grease them with grease on a cloth so they are no longer rusty brown but dark and lubricated. This removes the visible corrosion (which is the test point) and also prevents further moisture damage. And its never a bad thing to do anyway.
Some testers don't like you doing that, depends how pedantic they are, but they cant fail it on retest as the corrosion they noted is no longer visible.
As it was only an advisory, there is likely nothing to worry about. Clean them up and grease them as Luke and Simon also said and you will be golden next time. Keep your £300 in your pocket. Get a 2005-2009 RRS (FAH500210) sat nav/dash mat here - the one that wasn't there when you bought the car.
Spiffing wheel centre caps available
Post #451149 Tue Feb 03 2015 9:48pm
Simon73
United Kingdom 2007 Range Rover Sport TDV6 HSE Buckingham Blue
Mine had the same on the rear on my sheet from the LRD it says £75 or £90 in VAT fitted
Post #451733 Sat Feb 07 2015 7:23pm
jack.bauer
Is this something that would be covered under warranty?
Got the all singing dancing extra care by warranty direct.
Advisory: "Corroded gas suspension unit slightly deteriorated"
Also, not on MOT but health check shows flexi hoses due change under "steering & suspension" section 07 TDV8 + BAS map
Post #456107 Mon Mar 16 2015 8:14pm
wastower
Scotland 2006 Range Rover Sport TDV6 HSE Arctic Frost
Just been looking through my Warranty direct policy for a potential claim on suspension arm bushes but no can do and saw they don't cover brake pipes
Post #456197 Tue Mar 17 2015 1:01pm
fandrover
Hi all
A quick search brought me to this thread.....
can I just check if anybody has actual experience of having the rear corroded brake lines replaced and at what cost?
Only I can see on this threads quotes of £75... £300... and on a similar thread the guru Bobby saying it's a body off job with quotes of £2000
Rather a vast range of prices there!
Or likewise has anybody done the job themselves (with body on Wink )
Thanks
Post #461552 Fri May 08 2015 6:54pm
gazzc
2005 Range Rover Sport TDV6 HSE Siberian Silver
i was rubbing an advised one down with a bit of emery ready to grease it up and it started leaking ....its a brake pipe!!! i for one would like to know its in a good state when I'm hurtling along the motorway with 2 ton plus and hit the brakes Rolling Eyes silverRRS 2.7 TDV6 22"WHEELS FULL COLOUR CODE,STEPS,REMAP..gone
Rimini red rrs 2.7 tdv6 steps. Full c code. Recon engine!!loved but!gone ,thank god !!
Gone rr sport supercharged. Loved but 11mpg !!!
current,triumph stag mk2...current bmw 325 sport convertible
Post #461554 Fri May 08 2015 7:06pm
fandrover
Unfortunately I have no decision to make as whether to clean or fix...... a push of the pedal = fluid puddle on the floor!
Post #461557 Fri May 08 2015 7:18pm
gazzc
there you go ...does 300 quid matter on brakes...of course it doesn't,get real guys f f s Shocked silverRRS 2.7 TDV6 22"WHEELS FULL COLOUR CODE,STEPS,REMAP..gone
Post #461562 Fri May 08 2015 7:23pm
fandrover
Huh???
Have I missed something???
Nowhere have I complained or questioned £300.
All I asked was what have people actually paid as I've read £75, £300, £2000
Surely anyone would agree that's a big range of prices!
I'm really not sure that warrants either 'get reals' or 'FFS'????
Not
Post #461563 Fri May 08 2015 7:29pm
gazzc
yes prob my mistake there ..not bein sarky or anything ...red wine taking over my replies Embarassed silverRRS 2.7 TDV6 22"WHEELS FULL COLOUR CODE,STEPS,REMAP..gone
Post #461564 Fri May 08 2015 7:33pm
fandrover
Haha no worries, Fridays are meant to be drowned in red wine Wink
Post #461567 Fri May 08 2015 8:01pm
gazzc
cheers my eyes don't work right and my fingers belong to someone else Rolling with laughter silverRRS 2.7 TDV6 22"WHEELS FULL COLOUR CODE,STEPS,REMAP..gone
Post #461572 Fri May 08 2015 8:19pm
