![]() | Home > Maintenance & Modifications > Car passed MOT but …... |
tanloverluke Member Since: 19 Mar 2013 Location: Honiton Posts: 917 ![]() ![]() ![]() |
I had that on an advisory 2 years back. I fixed the problem with a wire brush. Sailed through the subsequent MOT.
simon645 Member Since: 30 Jan 2014 Location: cumbria Posts: 126 ![]() ![]() ![]() |
Common thing put on mot sheet, usually clean and wax oil and the job a good one |
Stuart Member Since: 17 Oct 2013 Location: Manchester Posts: 581 ![]() ![]() ![]() |
I used to have tested a lot of Class 7 commercial vehicles at one time, and some testers love this one. If they are deeply crusty and liable to spring a leak, maybe, but a bit of surface rust is often enough for a tester to call them corroded when they are alright really.
Simon73 Member Since: 20 Apr 2014 Location: Lichfield Posts: 23 ![]() ![]() ![]() |
Mine had the same on the rear on my sheet from the LRD it says £75 or £90 in VAT fitted |
jack.bauer Member Since: 30 Sep 2012 Location: london Posts: 277 ![]() |
Is this something that would be covered under warranty?
wastower Member Since: 12 Sep 2013 Location: Dunoon Posts: 21 ![]() ![]() ![]() |
Just been looking through my Warranty direct policy for a potential claim on suspension arm bushes but no can do and saw they don't cover brake pipes |
fandrover Member Since: 08 May 2015 Location: london Posts: 4 ![]() |
Hi all
gazzc Member Since: 07 Jan 2010 Location: cheshire Posts: 494 ![]() ![]() |
i was rubbing an advised one down with a bit of emery ready to grease it up and it started leaking ....its a brake pipe!!! i for one would like to know its in a good state when I'm hurtling along the motorway with 2 ton plus and hit the brakes |
Unfortunately I have no decision to make as whether to clean or fix...... a push of the pedal = fluid puddle on the floor! |
there you go ...does 300 quid matter on brakes...of course it doesn't,get real guys f f s |
Huh???
yes prob my mistake there ..not bein sarky or anything ...red wine taking over my replies |
Haha no worries, Fridays are meant to be drowned in red wine |
cheers my eyes don't work right and my fingers belong to someone else |
