Home > General (L494) > Surround cameras
Solihull1
Surround cameras
I have approx 2" clearance on the width of my garage to park a new RRS when the mirrors are folded in... I imagine that the surround cameras would help watch the sides if I was to tape the lines on the floor.... Do the side (kerb) cameras work when the mirrors are folded???
Thanks
Post #455864 Sat Mar 14 2015 9:42pm
alexv
How do you open the doors to get either in or out of the car when in the garage? On order expected October 16 macan turbo
Current car MY15 Hse Dynamic
Cayenne v6 MY64
RRS MY13 Black edition
Discovery MY61 xs
RRS TDV6 MY07
XC90 Executive
Yada yada yada
Post #455866 Sat Mar 14 2015 9:46pm
Solihull1
Good question... Perhaps I wasn't clear.. The opening is the problem with minimum clearance as I have a double garage but it has a central structural column - so no issue once I have the RRS in the garage... Issue is ensuring I do not scratch it on the way in!
Post #455872 Sat Mar 14 2015 10:11pm
ilard
Yes, surround cameras still work when the mirrors are folded. You would need painted lines as you describe for them to be useful through I tight gap, though. I'd probably add something soft, thin but spongy to the critical parts of the opening if poss. And don't drink n park. L405 P400e Autobiography (MY2020)... Silicon Silver / Espresso
Post #455881 Sat Mar 14 2015 11:07pm
Solihull1
Suround cameras etc
Ilard - thanks for the info!
Post #455975 Sun Mar 15 2015 8:20pm
Garage Door Medic
United Kingdom 2013 Range Rover Sport SDV6 HSE Santorini Black
Knock the middle pillar out, put a full length RSj over the top and install a nice new double door with remote control. Very Happy MY 13 3.0 SDV6 HSE Black Edition
Santorini Black
Ivory Premium Leather
Side steps
Disklok !!!!!!!
Mud Flaps
Spare wheel protector
Post #455980 Sun Mar 15 2015 8:50pm
Solihull1
Oh if it were only so simple! I have fitted two new electric garage fibre glass doors in the last 12 months! Will have to get more confident with the parking... I currently have an XC90 Sport and no issues with parking.. One to get used to...
Post #455986 Sun Mar 15 2015 9:19pm
Sb7019
I have the same issue and guide the vehicle in using the front cameras, making sure that exactly the same amount of garage is showing on both camera views. Having coach doors helps with this as they project outside the garage. If you have up and over doors then a line drawn or taped to the exact centre of the garage floor could also be used to align against - making sure that you see exactly the same amount of the line in both front camera views. I also drop the windows and feel the gap between the folded mirror and the door jamb as I drive in. It's quite nerve wracking the first few times but you soon gain confidence - though would not recomend it if you are overconfidedent due to too too much alcohol!
Having the camera system is worth it for me for this purpose alone.
Post #456051 Mon Mar 16 2015 2:04pm
Paulcp
2013 Range Rover Sport SDV6 HSE Atacama Sand
That's exactly what I did Rolling Eyes Also means I can put 1 car in the centre to make DIY jobs much more accessible and easier.
Really can't understand why double garages are built with a central pillar and 2 doors
Post #456065 Mon Mar 16 2015 4:08pm
Tim in Scotland
It might have something to do with stopping whatever is built above the garage from falling on top of your RRS that is parked inside the garage............ just a guess, I'm not a structural engineer but I do look after 400m long container ships and they bend hugely! 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #456069 Mon Mar 16 2015 4:38pm
Paulcp
More likely the price of 2 small RSJs vs 1 large one. I can let you have the structural calculations if you wish Whistle
Post #456093 Mon Mar 16 2015 7:11pm
eddkawasaki
Stupid isn't it. I was lucky enough to get the builder of my new place to change it to one electric door during build. variation cost was less than putting a personnel door in the side of the garage.
Post #456098 Mon Mar 16 2015 7:22pm
Dave777
Long things bend! If they don't they break. My plane bends a lot and that is good! It's only 200 foot though!
Post #456100 Mon Mar 16 2015 7:24pm
Solihull1
Thanks all... It appears the solution will be to tape two lines to the floor and use the surround cameras...
Post #456138 Mon Mar 16 2015 10:35pm
