![]() | Home > General (L494) > Surround cameras |
alexv Member Since: 02 Mar 2015 Location: beds Posts: 51 ![]() ![]() |
How do you open the doors to get either in or out of the car when in the garage? On order expected October 16 macan turbo
Solihull1 Member Since: 01 Mar 2015 Location: Solihull Posts: 87 ![]() ![]() |
Good question... Perhaps I wasn't clear.. The opening is the problem with minimum clearance as I have a double garage but it has a central structural column - so no issue once I have the RRS in the garage... Issue is ensuring I do not scratch it on the way in! |
ilard Member Since: 20 Aug 2010 Location: London Posts: 975 ![]() ![]() |
Yes, surround cameras still work when the mirrors are folded. You would need painted lines as you describe for them to be useful through I tight gap, though. I'd probably add something soft, thin but spongy to the critical parts of the opening if poss. And don't drink n park. L405 P400e Autobiography (MY2020)... Silicon Silver / Espresso
Ilard - thanks for the info! |
Garage Door Medic Member Since: 02 Feb 2014 Location: North West of UK Posts: 197 ![]() ![]() ![]() |
Knock the middle pillar out, put a full length RSj over the top and install a nice new double door with remote control. |
Oh if it were only so simple! I have fitted two new electric garage fibre glass doors in the last 12 months! Will have to get more confident with the parking... I currently have an XC90 Sport and no issues with parking.. One to get used to... |
Sb7019 Member Since: 24 Mar 2014 Location: Essex Posts: 2 ![]() ![]() |
I have the same issue and guide the vehicle in using the front cameras, making sure that exactly the same amount of garage is showing on both camera views. Having coach doors helps with this as they project outside the garage. If you have up and over doors then a line drawn or taped to the exact centre of the garage floor could also be used to align against - making sure that you see exactly the same amount of the line in both front camera views. I also drop the windows and feel the gap between the folded mirror and the door jamb as I drive in. It's quite nerve wracking the first few times but you soon gain confidence - though would not recomend it if you are overconfidedent due to too too much alcohol!
Paulcp Member Since: 18 Apr 2013 Location: Suffolk Posts: 327 ![]() ![]() |
That's exactly what I did ![]() Really can't understand why double garages are built with a central pillar and 2 doors |
It might have something to do with stopping whatever is built above the garage from falling on top of your RRS that is parked inside the garage............ just a guess, I'm not a structural engineer but I do look after 400m long container ships and they bend hugely! 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
More likely the price of 2 small RSJs vs 1 large one. I can let you have the structural calculations if you wish |
eddkawasaki Member Since: 23 Feb 2015 Location: Lancashire Posts: 93 ![]() ![]() |
Stupid isn't it. I was lucky enough to get the builder of my new place to change it to one electric door during build. variation cost was less than putting a personnel door in the side of the garage. |
Dave777 Member Since: 15 Feb 2015 Location: Sussex Posts: 485 ![]() ![]() |
Long things bend! If they don't they break. My plane bends a lot and that is good! It's only 200 foot though! |
Thanks all... It appears the solution will be to tape two lines to the floor and use the surround cameras... |
