![]() | Home > Maintenance & Modifications > Help with HID bulbs 4300K 6000K 8000K 10000K ?? |
sagalout Member Since: 26 Feb 2013 Location: Harrogate Posts: 128 ![]() |
Go for 4300k for OEM look - the higher the number the bluer the light. 5000k is supposed to be the ideal |
RonyTed Member Since: 03 Feb 2013 Location: Cannock Posts: 17 ![]() ![]() ![]() |
Hi, the lower the number 4300k will give a yellow light, the higher the number 10000K will give a blue light. I have fitted 6000k which gives a crisp white light (this is about as high up the scale you can go and still stay legal) and looks good if you change the side lights to 6000K LEDS.
Ian.H Member Since: 04 Oct 2014 Location: England Posts: 180 ![]() ![]() ![]() |
Also remember that the higher you go, the less bright the lights will actually be. 4300k is meant to be the brightest AFAIK, 6000k will have a distinct blue tint to them (bought these for my old E30).. and once you get past about 12000k I think, maybe slightly higher, they actually start to change colour completely.. with purples, greens, etc.. just FWIW |
If you want maximum light output, go for 4300k. 5000k if you must but 6000k will just be reducing the output. |
stebenny Member Since: 15 Dec 2013 Location: leyland, Lancashie Posts: 120 ![]() ![]() ![]() |
Thanks everyone for your help, I have gone for the 6000k ones they will be here monday so i will see what they look like, Thanks |
Russben Member Since: 27 Mar 2013 Location: Lancashire Posts: 278 ![]() ![]() ![]() |
I'm sure I've seen you around so I'll keep an eye out for you & let you know how they look. I'm in the shed, I'll be back in the real world in a minute. |
robertevans68 Member Since: 28 Jan 2015 Location: Cheshire Posts: 5 ![]() ![]() ![]() |
I recommend these: http://www.hids4u.co.uk/501-led-bulb-long-...white.html I find the 5000k ones match the OEM (4300k) bulbs well. (Re xenon bulbs, my recommendation is as above.) |
Thanks I will take a look now. |
