Home > Maintenance & Modifications > rear passenger side injector removal guide / advice
mswesty
Wales 2005 Range Rover Sport TDV6 HSE Java Black
hi
whilst carrying out other repairs over the weekend (tank fuel pump replacement, any questions please ask!)
i heard a hiss or air release on every turn of the engine. i traced it to the passenger side rear injector being loose and smoke/ fuel can be seen escaping while the car is running .
I'm hoping its the seals but my local land rover specialist says they are not available as separate parts.
has anybody any experience of replacing or locating the parts please?
best regards
mike
Post #455367 Mon Mar 09 2015 10:20pm
Disco_Mikey
I replaced all 6 of my injectors on Saturday just past
http://disco3.co.uk/forum/topic126044.html
Freelander TD4 injector washers fit just fine Thumbs Up
Post #455376 Mon Mar 09 2015 11:03pm
mswesty
thanks
thank you
Post #455382 Mon Mar 09 2015 11:13pm
DerrekL
great walk through of how to change injectors. Just a couple of questions regarding your process.
1) did you have to use a puller on any of the injectors you took out, or once the two bolts are out and surrounding pipes removed, does the injector pull out no problem?
2) you show replacement of bottom copper washer. Is there a top copper washer that needs replacing?
Cheers,
Post #468391 Thu Jul 23 2015 10:23pm
Disco_Mikey
1) No (but my seals were not leaking)
2) No
Post #468400 Fri Jul 24 2015 5:55am
DerrekL
Disco_Mikey - do I have to bleed the fuel system after changing only one injector? If yes, can you please list the steps on how to do this or is there a guide that you know of on here? Thumbs Up RRS 2.7 HSE Stornoway Grey
P38 4.6 HSE V8
Post #504644 Tue Sep 06 2016 9:47am
