Home > General > Quick 4 month review.....with a few minor issues! |
frostmotorsport Member Since: 14 Apr 2014 Location: Wellington Posts: 79 |
I'm no expert, but here is my 2c (2p for those of you in the UK) worth...
Sat Feb 28 2015 8:32pm |
Here are a few suggestions to try and help with your issues...
You really need to get your dealer to fix this problem first, but an option to disable it in the mean time... With ignition on, sit in the drivers seat, plug then unplug the seatbelt 9 times in succession. This should disable the bong. If it doesn't diable the bong for the passanger seat, then carry out the same process in that seat.
Do you use different key fobs? One key fob may be programmed to dip the mirrors, and the other key fob not. This can be turned off in the menu on the dash.
Again, this can be changed in the menu on the dash, I think it comes under access mode.
There is a software update to cure this issue, get in touch with your dealer. Hope this helps. |
Sat Feb 28 2015 8:58pm |
peterg1965 Member Since: 20 Sep 2014 Location: Lancashire Posts: 81 |
That's a real help, thank you.
Sat Feb 28 2015 9:50pm |
Mr Rusty Member Since: 17 Jan 2016 Location: Aberdeen Posts: 376 |
Peter?
Wed Jan 27 2016 10:58pm |
