![]() | Home > Technical > IID Tool question |
How's your battery? The HDC fault message is the number one indicator of a poor battery and/or alternator. |
Battery is tip top. Its a fairly new LR AGM technology version and I give it a full charge every now and again with CTEK MX5.0. So don't think it is the usual battery problem. 2008 MY Java Black TDV8 HSE
tattooal Member Since: 20 Jun 2014 Location: Pegswood, Morpeth, Northumberland Posts: 1 ![]() ![]() ![]() |
Hi there, could the whirring noise be the disc in the Nav DVD player underneath the passenger seat? |
Thanks for the suggestion but would say it is not the sat nav as I'm familiar with that noise and it is better described as a series of clicks with a very subdued whirr.
Yes when you clear the faults or do a flash update then the car is rebooted, what you can hear is indeed the servo motors in the gearbox, also the BCM make's a noise as well as the locks relays.
