Home > Technical > IID Tool question |
Lost for Words Member Since: 15 Jan 2015 Location: Warminster, Wiltshire Posts: 1477 |
How's your battery? The HDC fault message is the number one indicator of a poor battery and/or alternator.
Wed Feb 04 2015 10:40am |
Battery is tip top. Its a fairly new LR AGM technology version and I give it a full charge every now and again with CTEK MX5.0. So don't think it is the usual battery problem. 2008 MY Java Black TDV8 HSE
Wed Feb 04 2015 11:12am |
tattooal Member Since: 20 Jun 2014 Location: Pegswood, Morpeth, Northumberland Posts: 1 |
Hi there, could the whirring noise be the disc in the Nav DVD player underneath the passenger seat? |
Thu Feb 26 2015 8:14pm |
Thanks for the suggestion but would say it is not the sat nav as I'm familiar with that noise and it is better described as a series of clicks with a very subdued whirr.
Fri Feb 27 2015 9:46am |
flack Member Since: 24 Feb 2013 Location: Preston Posts: 379 |
Yes when you clear the faults or do a flash update then the car is rebooted, what you can hear is indeed the servo motors in the gearbox, also the BCM make's a noise as well as the locks relays.
Fri Feb 27 2015 6:29pm |
Thanks Flack, you may have just helped to make a bit of a breakthrough on this fault I've been chasing for over 2 years!
Sat Feb 28 2015 2:26pm |
