![]() | Home > Technical > Warning lights coming and going |
I'd also get your alternator checked. Common problem on the TDV8's I'm afraid. |
Agreed. Get them both checked. Also, check that the battery is the correct one - it's not unknown for the wrong size battery to be installed. This doesn't help the alternator. 2012 SDV6 - it's missing a couple of cylinders
RRSMike Member Since: 01 Oct 2014 Location: Fife Posts: 32 ![]() ![]() ![]() |
Going to test with a voltage meter tomorrow before taking to the garage... What should I look for voltage wise? |
The reading with engine running and load on seems too low. Should stabilise in the 14v ish region if the alternator is working properly.
myfirstrrs Member Since: 20 Jan 2014 Location: Lancashire Posts: 433 ![]() ![]() |
I just checked voltage on mine. Not used it for a few days and before starting it had 12.0 volts, usually it sits at about 12.3 or so before starting. It started fine and jumped up to 14.3v with engine running. Battery was fitted new by LR dealer 6 months ago and from new it never had more than about 12.4 when cold. |
Left it overnight and checked the battery this morning before switching on the car. 12.4V, then I took it on a 5min drive and checked again. 14.8V. Strange. |
Follow up... Suspension light hasn't come back on since that one and only time. The park brake fault was due to a dodgy connection in the wiring in the rear chassis. £280 fix at LR dealer. |
kozzone Member Since: 26 Feb 2015 Location: Vaasa Posts: 21 ![]() ![]() ![]() |
Hi Mike! Could you tell more where the wiring problem was in the rear chassis? I´m having the same issues with the Park Brake Fault -light flashing at startup! It seems to amplify when I´m pressing gas pedal. But the problem goes away in a minute after startup. |
The usual place is the wiring in the wheel arches going to the EPB module. |
Sorry mate, I have no idea exactly where it was, all the dealer told me was what I said above. Apologies I can't be of more help. Think it was a pretty simple fix though. |
Just noticed this bit. I would check your alternator first. ![]() 2006 Discovery 3 TDV6 Auto HSE Zambezi Silver ![]() |
Thanks for the info! I have to check it next. Voltage seems to be quite ok. It´s 12.7V idle and about 15.4V when running idle. I dont know if thats a bit too high? Also when I press gass pedal and all this fault occurs, the engine rpm sails up and down about 100-200rpm and stabilizes when the fault goes away. Nav display also seems to boot it self during this |
12.7V with the engine off and car asleep is basically a 100% charged battery so that's good. I think 15.4V when idling is a tad high but hopefully one of the site sponsoring mechanics will be able to confirm. 2012 SDV6 - it's missing a couple of cylinders
