Home > Faults & Fixes > Range rover sport went dead 07 Hse TDIV6 |
monty19 Member Since: 12 Mar 2014 Location: boro Posts: 323 |
I've been to 2 independent garages for the alternator tested and both have readings of above 14 |
Tue Feb 24 2015 12:37pm |
samorano Member Since: 23 Feb 2015 Location: Manchester Posts: 11 |
hello good one you got there. so pls was the hazard lights still blinking when the ignition was switched ON immediately the new battery was fitted before clearing the fault codes? |
Tue Feb 24 2015 7:18pm |
Yes they did, I switched them off and made sure everything else was off before starting it |
Tue Feb 24 2015 7:36pm |
FatJoe Member Since: 13 Dec 2014 Location: Staffordshire Posts: 259 |
Possibly got the lower reading from the sat nav screen. I'm not Fat. RRS TDV6 HST. |
Tue Feb 24 2015 7:48pm |
and hw did you switched them off? was it by clearing all the fault cods? and one more important question, after fitting in the new battery, did the engine management light came up or it was only after switching off the other lights before it finally came cuz i want to be sure if its the same situation i am facing |
Tue Feb 24 2015 8:11pm |
This was off the self test menu on the nav screen |
Wed Feb 25 2015 7:04am |
When I fitted the new battery the indicators started to flash, I turned them off on the dash before putting the key in the ignition, not sure if its relevant but after turning the key I made sure everything was turned off, heater seats etc, all the faults were still there when I started it including the check engine light. All the faults cleared quite quickly except the eml, this cleared after I stopped it and restarted it, hope this helps Tony |
Wed Feb 25 2015 7:11am |
Wed Feb 25 2015 7:14am |
with mine, the eml donot even show up on the instrument cluster here is a video to mine i hv also tried the self diagnostic but nothing like a fault shows up so there is no way for me to clear out the faults |
Wed Feb 25 2015 11:07am |
Not sure if this will make a difference, I had no battery on the car for 2 days, you could try this and see if it works or search for the hard reset procedure |
Wed Feb 25 2015 11:43am |
Lost for Words Member Since: 15 Jan 2015 Location: Warminster, Wiltshire Posts: 1477 |
I highly suspect you have a problem on the CANBUS somewhere. The only way you can deal with it is to start running over the wiring - a diagnostic tool can't help.
hey the technician found out that the main socket carrying the CAN signals on the Electronic parking brake control unit was totally out and when it was connected, everything came back to normal except the EML which did not still show up but they could communicate with all the control units as the engine could crank but do not start . i now feel relieved . i am going to stay with them throughout the workout today to keep you guys inform thanks alot |
Thu Feb 26 2015 9:59am |
The EPB module and wiring is a common place for CANBUS problems. Visiting from DISCO3.CO.UK
Thu Feb 26 2015 10:07am |
Happy days |
Thu Feb 26 2015 12:46pm |
