Home > Maintenance & Modifications > HST BUMPER
B9BS X
HST BUMPER
Hi guys
Seen a HST Bumper on fleabay for sale and is advertised to fit a 06-09 model RRS.
Would this also fit on my late 2005 RRS and are the Parking sensors the same?
Here is the ad...
http://www.ebay.co.uk/itm/221681751681?_tr...EBIDX%3AIT
Thanks Thumbs Up RRS SUPERCHARGED, 22 INCH ALLOYS, JAVA BLACK, FULLY COLOUR CODED
EVERY POSSIBLE SOFTWARE UPDATE INCLUDING - BLUTOOTH UPDATE, SATNAV ON THE MOVE, CLOCK ON DASH, 3 CLICK FLASH, GEARBOX RESET, COMPRESSOR UPDATE AND SUSPENSION LOWERED,
BLACK CODE RE-MAPPED, AUTOBIOGRAPHY'D, NEW EXIDE BATTERY, NEW DENSO ALTERNATOR
Post #453464 Mon Feb 23 2015 6:08am
ABSport
United Kingdom 2011 Range Rover Sport 3.0 TDV6 Autobiography Santorini Black
Yes it will fit your model year. Parking sensors should be the same. Thumbs Up
Post #453466 Mon Feb 23 2015 7:03am
Hi
The Rear Bumper fits straight on however you will need a few other bits. There is a reinforcing plate which goes under the top edge of the bumper under the tread plate to support the top edge of the bumper. Due to the HST bumper being deeper you will need the extra extension brackets which support the lower edge of the bumper at the rear and lower edge of the wheel arch, you will also need the tailpipe trims.
Post #453467 Mon Feb 23 2015 7:53am
B9BS X
Cheers for the advise guys.
Col, is the reinforcement plate seperate to the bumper like an add on or stuck onto the rear of a HST model car? or do you think it may already be fitted to the bumper itself? RRS SUPERCHARGED, 22 INCH ALLOYS, JAVA BLACK, FULLY COLOUR CODED
Post #453483 Mon Feb 23 2015 10:56am
Hi
The reinforcement panel is a separate item which fits under the top edge of the bumper to secure it and keep the top edge straight. The panel is part of the HST Body kit but is available as a separate item from L/R costs about £60.00 odd quid.
I might have the part number somewhere if you need it.
Post #453493 Mon Feb 23 2015 12:30pm
B9BS X
Cheers Col
If you can get the part number that would be great Thumbs Up RRS SUPERCHARGED, 22 INCH ALLOYS, JAVA BLACK, FULLY COLOUR CODED
Post #453632 Tue Feb 24 2015 6:10am
Hi
LR009025
Post #453635 Tue Feb 24 2015 7:06am
