Home > Technical > The old suspension chestnut - help!
fascinuk
United Kingdom 2006 Range Rover Sport Supercharged Rimini Red
Range Rover Sport Problems 206 4.2 S/C
Sorry if this has been repeated after reading some other posts, but just think this is a little bit different
When driving on Motorway/Dual Carriageway/A road after 10 /15 minutes I get the amber warning light come on dash (far left) saying that there’s a suspension fault and vehicle will lean when cornering.
Drive on a lillte bit further and get HDC not available warning, Special Programs not available, Cruise Control saying Driver Intervened and cancels itself and Suspension lowered also 2 more amber warning lights as per picture. It still drives OK but not with any of the features listed.
The daft thing is, I live quite rural and it does not happen when driving on a B roads or country lanes with loads of potholes or uneven surfaces…… any ideas please, also any recommendations of where to take it to get it checked out in Cornwall/Devon - thanks
 Roger
Post #452414 Fri Feb 13 2015 12:08pm
Lost for Words
First things to consider:
Battery and alternator voltages.
Brake bulbs and switch.
Given the cruise control saying "Driver Intervened", by bet would be on the brake switch. Thumbs Up Visiting from DISCO3.CO.UK
Post #452415 Fri Feb 13 2015 12:38pm
scarey
lose height sensor ?
Post #452416 Fri Feb 13 2015 12:45pm
D12TYJ
United Kingdom 2012 Range Rover Sport SDV6 HSE Buckingham Blue
I would go with lost for words, as hes mentioned exactly what am about to write,
Have a very strong feeling its the alternator.
When the alternator starts to spike the voltages, this usually happens 99% of the time,
By again i could be wrong, but thats my advice.
Post #452464 Fri Feb 13 2015 8:46pm
Lost for Words
With the RRS and D3/4s having complex electronic systems, low or high voltage can cause havoc and it always the first thing to check. Particularly at this time of year too as batteries start to struggle in cold weather. I would suggest that a multimeter is an essential piece of equipment for any RRS owner. Thumbs Up
@ the OP. Do the heights appear normal on the 4x4 info screen?
Another consideration, given the "lean in corners" message could be ABS sensors and the steering angle sensor (SAS). Visiting from DISCO3.CO.UK
Post #452485 Sat Feb 14 2015 9:46am
fascinuk
Thanks for these hints guys, what should the alternator and battery voltages run at?
Thanks Roger
Post #452491 Sat Feb 14 2015 11:31am
Lost for Words
A good, fully charged battery standing charge should be 12.7/12.8 volts.
The alternator will vary, partly depending on the battery, but 14.3-14.5 is quite normal. Up to about 15.2 is seen with poorer batteries/colder conditions. Anything in the low 13.Xs and below or high 15.Xs and above would be bad.
Post #452494 Sat Feb 14 2015 11:51am
fascinuk
Thanks Lost For Words, will get these checked out on Monday, really appreciate your help mate Roger
Post #452499 Sat Feb 14 2015 12:07pm
Lost for Words
No problem; I like to help when I can. Thumbs Up Visiting from DISCO3.CO.UK
Post #452501 Sat Feb 14 2015 12:28pm
shakeapaw
Im more interested in the full tasnk of fuel ha ha, I bet this is because of the drop in prices, is every body driving round on a full tank? 07,TDV8,Black, Black Heated leather all round, Rear Entertainment with Headpones & Remote, TV, DVD, Pure Dab Digital Radio, Sidesteps, Adaptive Headlights, sunroof, now working fuel burning heater Smile)))
Post #452539 Sun Feb 15 2015 12:07am
JCHarris
Can't be posting pictures publicly looking like a cheapskate!! Laughing 2010 TDV8 Santorini Black. Side steps done. Remote parked heating done. Next up...Autobiography body kit.
2007 Disco 3 Java Black. Phantom Body Kit. Gone and not forgotten. Love Big Dog.
Post #452774 Mon Feb 16 2015 10:21pm
fascinuk
Hi, quick update, had battery and alternator checked and its reading 14.4 volts, so assume that there's no probs there!
Will now check brake switch as brake lights and bulbs are all OK .
Anyone with any further ideas are welcomed as the Suspension Fault light in the display is still coming on and Vehicle will lean when Cornering is still being displayed!
Cheers guys
Roger Roger
Post #453940 Thu Feb 26 2015 5:07pm
Rob_h
If it's like a d3 I had a problem with the connector within the front passenger wheel arch which is a known problem on the d3 ? Not sure if it's the same on the rrs though but might be worth a check ?
Post #453948 Thu Feb 26 2015 5:25pm
Lost for Words
The wheel arch wiring and connectors can cause issues but there aren't the signs of a full CANBUS hissy fit and the simple things need to be ruled out first.
I think the most likely culprits are the brake switch, steering angle sensor, ABS sensor or height sensor/associated wiring. Thumbs Up
It could also be something ACE related (of which I have no knowledge, I'm afraid). Visiting from DISCO3.CO.UK
Post #453950 Thu Feb 26 2015 5:35pm
fascinuk
Update : New brake switch fitted and had the 'suspension fault vehicle lean when cornering' warning come up.....so it's not the brake switch, battery or alternator .......next??!!! Roger
Post #463274 Sat May 30 2015 11:41am
