Home > Technical > The old suspension chestnut - help!
Lost for Words
TBH, I think I'm leaning (no pun intended!) towards an ACE related problem now. If you can get access to some diagnostics somewhere then that may be more enlightening. Thumbs Up
Did you check the heights on the 4X4 screen? Question Visiting from DISCO3.CO.UK
Post #463282 Sat May 30 2015 3:21pm
fascinuk
United Kingdom 2006 Range Rover Sport Supercharged Rimini Red
UPDATE, have just found out the problem......steering wheel sensor was at 18% now reset to 0 % and have not had suspension fault registered anymore.....it assumed I was oversterring by 18% causing ' vehicle to lean when cornering ' and then registering the fault which then snowballed and all the other listed faults started.....and breathe!!!!!!
Thanks for all your hints, but Mick Moores Landrover at Winnards Perch Cornwall you're top men Roger
Post #469243 Sun Aug 02 2015 6:11pm
Lost for Words
Glad to hear it's sorted. Thumbs Up Visiting from DISCO3.CO.UK
Post #469245 Sun Aug 02 2015 6:38pm
