Home > General > knocking driving me MAD
wings21660
United Kingdom 2011 Range Rover Sport 3.0 TDV6 Autobiography Fuji White
hi all, ime new to this site & ime hopng somebody out there can help. I have owned my rrs for three & a half years now, & it has cost a pretty penny to keep it on the road, having replaced discs, pads & calipers to the rear, both egr valves, alternator all the work comes to approx Ģ3000. The latest repair bill is still on going, there has been a knocking coming from the front passenger side, so the mechanic took it to his garage, replaced the the hub bearing on the front passenger wheel & said that should fix the problem, but it did'nt. When I got the car back it was just as bad, phoned the garage they took it away again sent it back saying they could'nt find anything wrong, is there anybody out there can point my mechanic in the right direction many thanx wings.
Post #452262 Wed Feb 11 2015 7:59pm
cossiedave
England 2006 Range Rover Sport TDV6 Autobiography Zambezi Silver
hi and welcome mate , get him to check the d bushes on roll bar
Post #452263 Wed Feb 11 2015 8:08pm
JasM
Scotland 2012 Range Rover Sport SDV6 HSE Orkney Grey
Either lower arms or Anti roll bar bushes. 2014 L405 SDV8 RR Autobiography Cool
2012 RRS SDV6 HSE -Orkney Grey with A/B bodykit - Now Gone Sad
2007 RRS TDV6 HSE - Zermatt Silver - Gone
Post #452267 Wed Feb 11 2015 8:24pm
wings21660
Thanx guys will speak to mechanic tomorow, will update if there is a fix
Post #452269 Wed Feb 11 2015 8:31pm
cossiedave
you need to disconnect the drop links to see if d rubbers are knacked
Post #452272 Wed Feb 11 2015 8:41pm
wings21660
cheers dave will do
Post #452274 Wed Feb 11 2015 8:50pm
ABSport
United Kingdom 2011 Range Rover Sport 3.0 TDV6 Autobiography Santorini Black
Yes this is true either drop links or ARB Bushes are worn. I had my bushes and drop links done at the dealers and it was not that bad, If I recall drop links were Ģ140 fitted. Front ARB Bushes were Ģ83 all in.
Post #452293 Thu Feb 12 2015 2:18am
Maxarn58
Sweden 2006 Range Rover Sport TDV6 HST Java Black
Hello Wings.
Is the front knocking when going over uneven urfaces, itīs most probably Antiroll bar,
bushings and/or droplinks.
If the knock appears when "tapping" the brakes in low speed, itīs the
bushings in the lower front arms.
If itīs all the above, then itīs all the above..
I have just been over to Your fair lands doing all of the above, and my, what a difference,
Iīm driving what feels like a new car..
It made a dent in the wallet though, but compared to doing it here in the northern countries, where
they cut out all the spare parts from solid blocks of gold, (or it seems that they are doing that),
it was well worth everey penny.
I had it done by a very good Independent in Somerset.
Rgds
Uffe As a rule, I always resist temptations,
unless they are irresistible.
My Ride: 2006 RRS HSE TVD6 Java Black/Cherry Woods with HST factoryfitted pack.
Post #452309 Thu Feb 12 2015 8:50am
wings21660
My mechanic has checked all of the above and is still beat, I watched him doing a bar test while it was up on the ramp and he could'nt find a thing wrong back to the drawing board me thinks:blub:
Post #452341 Thu Feb 12 2015 3:03pm
cossiedave
Did he disconnect the drop links
    Post #452365 Thu Feb 12 2015 5:15pm
    simple1
    Need to have some weight on the wheel to test the joint on RR. If you jack them up to full travel or left them off the ground it appears that there is no wear. 2x TDV6. SE and HSE. Both returned to sender with issues👀
    Post #452381 Thu Feb 12 2015 8:01pm
    wings21660
    he did'nt dave what would that do so i can tell him
    Post #452434 Fri Feb 13 2015 3:35pm
    cossiedave
    The drop links put tension on the anti roll bar and stops you seeing any movement but if you disconnect them you will see if there is any movement. It takes about 10 minutes to check them mate
    Post #452453 Fri Feb 13 2015 6:10pm
    wings21660
    cheers dave will see the mechanic on monday
    Post #452455 Fri Feb 13 2015 6:17pm
    Bomber H
    Did you sort it?
    I had my ARB bushes replaced the other day, as the front end was a bit crashy, and wow what a difference the replacements have made, feels like new again! Thumbs Up 2016 VW Golf GTD DSG
    2007 Exige S British GT SE
    Gone : 2011 3.0TDV6 HSE, Stornoway Grey, Ivory, Piano Black Trim, Paddleshift, Privacy Glass, Side Steps, Mud Flaps, Heated Steering Wheel, Timed Climate & Remote Park Heating Smile
    Post #452840 Tue Feb 17 2015 9:12pm
