Home > Maintenance & Modifications > Help with light bulb replacment |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8982 |
H7 is the headlight main beam fill-in bulb. Sidelights are 501 W5W. Reversing lights are 382 I think. You need two of each.
Mon Jan 19 2015 10:11pm |
stebenny Member Since: 15 Dec 2013 Location: leyland, Lancashie Posts: 120 |
Thanks for the reply, so do I need 4 H7 bulbs 2 for the headlights and 2 for the full beam, Thanks Steve |
Tue Jan 20 2015 10:32am |
Beancounter_74 Member Since: 11 Oct 2011 Location: Down here now... Posts: 5796 |
If you have Halogens, yes.
Tue Jan 20 2015 10:42am |
flydive Member Since: 16 May 2007 Location: South Posts: 1213 |
Do not trust the manual on headlight bulbs, check what you actually have. '08 RRS TDV8
Tue Jan 20 2015 12:57pm |
Thanks, This might sound daft but will mine be halogens i have a 2008 RRs |
Tue Jan 20 2015 6:08pm |
Techstyles Member Since: 22 Dec 2014 Location: Antwerp Posts: 46 |
Probably a stupid question but can you buy zenon H7 bulbs and replace the H7 Halogens? I dont even know what I have to be honest.
Thu Feb 12 2015 3:35pm |
Lost for Words Member Since: 15 Jan 2015 Location: Warminster, Wiltshire Posts: 1477 |
You can fit H7 bulbs that use Xenon gas to produce more light but these are not the same as an HID system which requires ballasts to create a higher voltage etc. An HID system operates by creating an electric arc rather than a filament. There are good HID kits available, and plenty of bad ones, but none are road legal. A decent, well fitted kit should not cause undue glare to drivers but it is still not legal. Visiting from DISCO3.CO.UK
Thu Feb 12 2015 4:09pm |
worth replacing the reversing with LED's from Advanced Factors IMO ON THE WAY: BMW F21 M140i
Thu Feb 12 2015 5:29pm |
Ok but say I have the H7/11 Halogen bulbs, can i then opt to use these xenon bulbs instead?
Fri Feb 13 2015 3:26pm |
While, I think, you might be able to get the D2S bulb to fit in an H7 with an adapter, you would have to ensure the arc remains at the focal point of the reflector. The slightest change (even just 1mm) has a dramatic effect on the light output. You would also have to purchase ballasts and wire them in or the bulbs would not function. In short, you could not just replace the H7s with those.
Fri Feb 13 2015 4:14pm |
Thanks, to be honest I dont even know if I have the xenons but i think i do........lmao is there an easy way to check or do I have to remove the light clusters. |
Fri Feb 13 2015 4:19pm |
