![]() | Home > General > Fuel Burning Heater |
sp1959 Member Since: 22 Aug 2015 Location: Leeds Posts: 18 ![]() ![]() |
i`ve just recently bought a 2005 range rover sport hse and ive noticed that the satnav software is quite dated, so looked for the official update disc from land rover but its quite expensive, is there anywhere else i can get the update disc from where its cheaper. |
harrygh60 Member Since: 16 Nov 2011 Location: London Posts: 395 ![]() ![]() ![]() |
My Facelift model was first registered 30/Sept 2009,it had the FBH fitted. But the software for timed heating was not loaded. I had this installed. It will only work if the temperature is below a certain level, and if the battery is good, and fuel level is good. I then bought and fitted the antenna,and reciever and blipper .And everything worked fine. In cold weather. ![]() ![]() |
KennyR Member Since: 28 Jul 2015 Location: Gourock Posts: 178 ![]() ![]() |
Good guide |
stagfinder Member Since: 17 Dec 2015 Location: Peterborough Posts: 22 ![]() ![]() ![]() |
put a shout out for a guy called bodsy hes your man and can work wonders he sorted mine no problem it now works from the lr button on my key fob |
Hi sp1959 you can get upto date copies that work fine for about £25 through eBay, fitted 2 a2012 and most res toy a 2016 just carn't thing what the company was called 2008 G4 RRSport TDV8 current
-------------------------------------------—------------------------------------------------------------------------------------------------ I bought the remote kit from Bodsy and went to fit this morning using JUCOTT01's superb guide above but when I got the panel off it looks totally different behind there, any ideas where the unit fits here?? ![]() Current: MY2023 3.0 SDV6 Autobiography in Eiger Grey Gone: MY2019 3.0 SDV6 Autobiography in Carpathian Grey Gone: MY2015 4.4 SDV8 Autobiography in Corris Grey with ebony and lunar leather Gone: MY2013 3.0 SDV6 HSE Black Edition in Orkney Grey, piano trim, black leather with contrast stitch |
Hi Kenny,
Brilliant, thanks Ian!! ____________________
Pakolainen Member Since: 14 Mar 2016 Location: Helsinki Posts: 310 ![]() ![]() ![]() |
After reading 12 pages on FBH i'm overwhelmed.
RRSCruiser Member Since: 02 Apr 2010 Location: West Sussex Posts: 41 ![]() ![]() |
Hi do you have any further info on this LE diagnosed fault. I am having the car intermittently shutting down and everyone is scratching their heads It's a long story and it's on a couple of threads I have posted to to explain whahas happened and happening currently. I'm laid up at the minute after an operation last week and am surfing to gather ideas of what to look for or check when I'm back on my feet Do you have any references for this TSB's or service recalls anything really Thanks in advance |
[quote="harrygh60"]
donny dog Member Since: 23 Nov 2016 Location: yorkshire Posts: 772 ![]() ![]() |
I've got a new SDV8 being collected on Wednesday, and, having just checked on TOPIx, it has a FBH fitted. This is a complete surprise to me, as I thought it was an expensive extra and no longer fitted as standard. Does anyone know how it operates on MY17 cars? Will it have remote facilities like discussed in this thread? |
It won't have the remote fitted as standard. The timed climate can be enabled on screen. I'd need to see if the connector is there for the Remote function, but I do have a different option for GSM enabled activation of the FBH. |
Bodsy, I'd certainly be interested in that. As soon as I've got the car I'll get in touch. |
