Home > Maintenance & Modifications > vibration/ brake squeal/ burning smell and handbrake fault |
Yes, they've not fitted/adjusted the epb shoes properly or you have a separate calliper issue, but the squeal indicates EPB. Bodsys Brake Bible
Tue Feb 10 2015 10:10am |
monty19 Member Since: 12 Mar 2014 Location: boro Posts: 323 |
cheers bodsy, cars on route now, id asked them if they had experience with range rovers prior to giving them the job |
Tue Feb 10 2015 10:28am |
You can quite often get the small L shaped wedge where it doesn't sit in the right position on one of the shoes. You need to tap it back so that the spreader isn't forcing them apart too much.
Tue Feb 10 2015 11:03am |
they gave me no info at all, didnt change the epb shoes just discs and pads, im not sure if they know about the bedding in procedure. |
Tue Feb 10 2015 12:02pm |
Garage is now saying the actuator is fooked apparently one week after new discs and pads fitted, we have always used the epb for a year with no issues at all, not sure if they did something wrong or didnt wind off the handbrake, looks like another big bill coming my way |
Tue Feb 10 2015 4:01pm |
It can be repaired if they can be bothered. I suspect that they didn't adjust the epb properly, causing the actuator to over extend and POP!
Tue Feb 10 2015 4:14pm |
when the wife put the epb on this morning she said it was making a loud noise and didnt stop so she turned the car off,im assuming this is when the damage was caused, it took 25 minutes after that to get it to come off |
Tue Feb 10 2015 4:18pm |
Lost for Words Member Since: 15 Jan 2015 Location: Warminster, Wiltshire Posts: 1477 |
If they did screw it up, don't let them go and screw up your new module.
The damage may have happened then but it was probably caused at the point they adjusted it. Visiting from DISCO3.CO.UK
Tue Feb 10 2015 4:19pm |
they are saying they followed the procedure for doing the job |
Tue Feb 10 2015 4:21pm |
