Home > Maintenance & Modifications > vibration/ brake squeal/ burning smell and handbrake fault
monty19
United Kingdom 2007 Range Rover Sport TDV8 HSE Stornoway Grey
new discs and pads fitted to the rear of the car a week ago and ive got all these things happening, anyone have a idea whats going on, im offshore at the moment and the mrs is paniking a bit, ive phoned the garage who are goinig to take a look but id like to know whats going on with it so they can sort this properley
tia
tony
Post #452022 Tue Feb 10 2015 10:03am
Bodsy
Site Sponsor
Yes, they've not fitted/adjusted the epb shoes properly or you have a separate calliper issue, but the squeal indicates EPB. Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #452024 Tue Feb 10 2015 10:10am
monty19
cheers bodsy, cars on route now, id asked them if they had experience with range rovers prior to giving them the job Evil or Very Mad
Post #452028 Tue Feb 10 2015 10:28am
Bodsy
Site Sponsor
You can quite often get the small L shaped wedge where it doesn't sit in the right position on one of the shoes. You need to tap it back so that the spreader isn't forcing them apart too much.
I suspect that it was tight when they tried putting the disk back on, but they persevered instead of fixing the cause.
Did they carry out the bedding in process on the EPB with the new disks? (did they change the epb shoes as well?)
Perhaps send them a link to my brake bible.... Whistle Bodsys Brake Bible
See it HERE
Post #452029 Tue Feb 10 2015 11:03am
monty19
they gave me no info at all, didnt change the epb shoes just discs and pads, im not sure if they know about the bedding in procedure.
Post #452037 Tue Feb 10 2015 12:02pm
monty19
Garage is now saying the actuator is fooked apparently one week after new discs and pads fitted, we have always used the epb for a year with no issues at all, not sure if they did something wrong or didnt wind off the handbrake, looks like another big bill coming my way Big Cry
Post #452068 Tue Feb 10 2015 4:01pm
Bodsy
Site Sponsor
It can be repaired if they can be bothered. I suspect that they didn't adjust the epb properly, causing the actuator to over extend and POP!
About £600 for actuator ISTR... plus fitting of course.... Bodsys Brake Bible
See it HERE
Post #452072 Tue Feb 10 2015 4:14pm
monty19
when the wife put the epb on this morning she said it was making a loud noise and didnt stop so she turned the car off,im assuming this is when the damage was caused, it took 25 minutes after that to get it to come off
Post #452076 Tue Feb 10 2015 4:18pm
Lost for Words
If they did screw it up, don't let them go and screw up your new module. Whistle
Always worth having a go at repairing it first. Thumbs Up Visiting from DISCO3.CO.UK
Post #452077 Tue Feb 10 2015 4:18pm
Lost for Words
The damage may have happened then but it was probably caused at the point they adjusted it. Wink Visiting from DISCO3.CO.UK
Post #452078 Tue Feb 10 2015 4:19pm
monty19
they are saying they followed the procedure for doing the job Evil or Very Mad
Post #452079 Tue Feb 10 2015 4:21pm
